04-21-2010, 07:06 AM   #1
*ist D problems updating firmware
Dear All, I've searched the web, called my country assistance for help but really no luck updating my firmware for *ist D.
I've followed instruction, so downloaded the file, put in a formatted flash, run the camera holding menu but no luck, it seems that the camera does not look at the flash (2 Gb, 1Gb and 64 Mb so no more than 4 Gb as stated) the only result is to visualize the version of my firmware (1.0)
Tried with new batteries so I'm simply getting crazy.... Any suggestion or help very very very appreciated
04-21-2010, 07:36 AM   #2
QuoteOriginally posted by GiorgioPentax Quote
Did you make sure to Unpack the BIN file and put it in the Root (base) directory of the card? If the file is in the DCIM directory, it will not work because the camera won't know where to find it.
04-21-2010, 12:39 PM   #3
Still problems, so i will explaing in detail what I've done.
1) charged rechargeable batteries to full
2) download firmware from pentax europe website for my ist D (Downloads - PENTAX Europe GmbH) to be sure not to have any problem of different names europe/USA
3) extracted the bin to a dir in my hard disk
4) checked the firmware on my camera (on + menu button)
it result to be ver 1.0 (appear for 5 second on my display)
5) formatted a SanDisk of 2 Gb (tried both with a lexar and a sandisk) 6) copied the bin file to the root directory (no DCMI directory)
7) put the flash in the camera... and push on+menu... nothing happens I see the ver.1.0 for 5 seconds and then the normal menu
I'm desperate (((((((((((
Any help appreciated
04-21-2010, 03:35 PM   #4
It sounds like you did everything exactly right. I'm afraid I can't help much further at this point but I'm bumping your post to the top anyway. Maybe somebody else can help..
You say your camera is an istD.. What kind of card are you using? If it is an SD card, read on. If it's a Compact Flash card, Read on anyway.
THE only thing I can think of is that you have the Wrong firmware. That is, there are Several versions of the *ist D cameras (D, DS,DS2,DL,DL2). If you have the wrong one, the camera will simply reject it and have the behavior you are seeing. I would like to think you know which camera you have but it is not impossible to believe you downloaded the wrong file.
04-21-2010, 06:06 PM   #5
When you put the file onto the CF card, make sure it is on the very first level of the card, not in a sub menu.
04-21-2010, 06:19 PM   #6
Lowell Goudge's Avatar
what version are you trying to load, the latest is 1.12
also make sure you are loading for an *istD, not DS, DS2 or DL
04-22-2010, 12:18 AM   #7
thanks to all for the reply. I love pentax and I love this forum, today I will give my camera to a friend of mine asking for update the firmware (without telling him anything just not to influence him). I hope everything will go fine and post what is the problem.
Giorgio
04-22-2010, 03:41 AM   #8
[langtitle=it]Solved ![/langtitle]
Solved ! the problem was in the corrupt file of firmware ! I did it a big thanks to everyone that helped me ! I love pentax and pentax community!
Giorgio
06-29-2013, 03:33 PM   #9
Where and how did you find out the firmware was corrupt? Where did you get new firmware that was not corrupt. I am having the exact same problem, my camera wont recognize the file and begin updating
*ist, camera, dslr, firmware, flash, gb, luck, photography
Updating Firmware on K-7. ronin67 Pentax DSLR Discussion 3 12-24-2009 10:19 PM
Firmware Updating to 1.30 Jesus Pentax DSLR Discussion 7 05-24-2008 07:01 PM
updating firmware MikeD Photographic Technique 4 03-23-2008 05:24 PM
Problems with updating my *istDL2 HenrikSchafranek Pentax DSLR Discussion 0 03-20-2008 10:50 AM
updating firmware CeeBee Pentax DSLR Discussion 3 12-09-2007 04:53 PM
All times are GMT -7. The time now is 08:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
