04-21-2010, 08:20 AM   #1
K20 Occasional Manual Focus Off
I've noticed on different occasional that I've gotten a few slightly out of focus portrait shots from my K20D set on manual focus on a tripod. Shake reduction is turned off. It's happened with a 50 A 1.4 and a 24 A 2.8. Most shots are sharp, but occasionally one or two are visibly slightly out of focus without having touched the camera or tripod. I can't explain it, other than maybe there is an issue with the sensor. Has anyone else seen this happen?
04-21-2010, 08:30 AM   #2
QuoteOriginally posted by Super A Quote
Anything is possible.. The first question I'd have, is the tripod on stable ground? Or is it on a floor that moves, even slightly, when you walk around? Being a heavy guy, I've noticed, particularly with longer exposures, that if I move around the shot will blur somewhat...
04-21-2010, 08:50 AM   #3
I guess another possibility is that you didn't focus the lens precisely. It is, after all, manual focus. I know that some of my manual focused photos aren't perfect. I don't use any add-on for focus, like a Katz-Eye. It might help you, if you don't.
04-21-2010, 09:02 AM   #4
You're using a couple of fast lenses there. Make sure to close down the aperture a bit to give you some depth of field to work with, and a split focusing screen helps a lot to verify focus. Other reasons might be that the subject moved and you're using a slow shutter speed. Also use a remote release (cable or infrared). I hope this helps...
camera, dslr, focus, photography, shots, tripod
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
Hi An occasional reader... drpage Welcomes and Introductions 2 01-25-2009 03:28 PM
K20 User Manual nulla Pentax DSLR Discussion 5 08-05-2008 04:54 PM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
All times are GMT -7. The time now is 06:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
