04-22-2010, 02:25 PM   #1
IR Photography on K2000
I'm getting a R72 52mm lens for my K2000 and it's stock lens.
What else will I need to do? I know I'll need a really long exposure, and a tripod..
Am I missing anything? All photo editing is done in Apples Aperture.
04-22-2010, 06:24 PM   #2
QuoteOriginally posted by evildragon Quote
Use manual white balance to set your White balance with the filter in place. When you're making your exposures, Cover the eye piece to keep stray light from getting in there (I use a towel). This was done with a K20d (as an experiment), FA43, f9, 30 seconds, ISO100..
Some may suggest that the WB can be set in post processing but in this case, it's far better to have it correct when you take the photo.
04-22-2010, 06:41 PM   #3
What would I set the white balance too?
04-22-2010, 07:11 PM   #4
The bottom one. You set it there and you fill the frame with the object you want to use as a reference. I use my concrete driveway. The sky sometimes works, the white siding on my house, and if all else fails, a gray or white card. Once you choose, simply press the shutter button. It will be saved as the custom setting (or a custom setting) until you change it. You may have to experiment to find what works best. Your goal is to get rid of the red cast that the R-72 is going to put on the photos.
From there, it's on to the post processing fun.
If you decide you REALLY like doing IR, you might want to look into a camera modified for IR..
More Here
04-22-2010, 07:13 PM   #5
Don't have the money to get another DSLR for IR. Gonna have to sit and wait with the 30 second exposure..
04-22-2010, 07:21 PM   #6
That's part of what makes it fun .. Experiment with ISO, aperture, etc until you find what works best. Note that everything that is true with noise in a DSLR exposure seems magnified when you put that IR filter on the lens. That's part of where covering the viewfinder helps for keeping out stray light.
There are also some point and shoot digicams that are particularly suited for IR. The Olympus 2020, the Panasonic FZ1, some of the sonys and nikons as well. With these, even with the R-72, you can go handheld (but the WB setting still applies).
There are a few IR masters around here (I'm not one of them) and once they spot the thread, they'll have plenty of advice.
04-22-2010, 07:24 PM   #7
My father has an FZ1, it was the camera I used to use before I got the K2000..
I tried a cheap flea market IR filter on my cell phone and video camera (which is 1080p HDV), but both have IR blocking filters and limited exposure settings, and boosting the stuff later resulted in nasty pictures.
Cell phone:
Video camera (in photo mode):
The pentax didn't like the cheap IR filter at all, hence I purchased an R72 that'll arrive soon in the mail once the seller ships it.
04-22-2010, 07:31 PM   #8
Well, cellphones may be ok as memory saving, moment capture devices but I don't think they make very good cameras (of any kind)..
Out of camera, FZ1
After a channel swap in photoshop (different photo)
04-22-2010, 07:44 PM   #10
I think you'll be able to get the hang of IR photography pretty quick. Those water shots with the FZ-1 are impressive. I've had a camera half ready twice in my life when I've seen a hawk and all I have to show for it is a blur. You're at least one up on me...
04-22-2010, 07:54 PM   #11
The lens I had available for the hawk was only a vintage 200mm Cosmicar KA lens. manual focus too..
04-23-2010, 04:00 PM   #12
rparmar's Avatar
I hate threads like this, because it stirs up my desire to get an IR modified camera. I guess I'll put that on the long list of things I am not allowing myself until after I resign from the ranks of the broke!
I do like seeing other people's shots, though.
What is the best alternative method people have found? R72 filter?
04-26-2010, 10:26 AM   #13
My R72 infrared filter came..
http://img.photobucket.com/albums/v395/Evilweredragon/ir-1.jpg
That is the result.. SO grainy, I had to shoot ISO400, 30 second exposure, with a wide aperture just to capture this. Otherwise I got blackness.
04-26-2010, 10:53 AM   #14
Yep, It's grainy alright... It'll take some experimenting and finessing of the WB and exposure to find what works best. Is this from a RAW file or is it the out of camera JPG?
04-26-2010, 12:03 PM   #15
From the RAW. I went into the gimp and channel swapped R and B, and auto leveled.
camera, dslr, ir photography, k2000, lens, photography
K2000 NR WillCarney Pentax DSLR Discussion 1 01-26-2010 02:53 AM
K2000 Duane Pentax DSLR Discussion 6 12-20-2009 05:28 PM
From K2000(K-m) to K-x, and question winglik Pentax DSLR Discussion 4 11-19-2009 11:16 AM
New K2000 sherib Troubleshooting and Beginner Help 13 06-08-2009 08:34 AM
k2000/Km has been out for a little while, what's your thoughts? CaymanImaging Pentax News and Rumors 24 02-04-2009 01:46 PM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
