04-23-2010, 07:48 AM   #1
techristian's Avatar
why is my viewinder so dark?
My Pentax *istD works fine with my telephoto lens letting plenty of light into the viewfinder, so that I can manually focus, but the stock 18-55 lens that came with it is SO DARK , even in sunlight, that it is difficult to focus. Am I doing something wrong?
Dan
04-23-2010, 08:15 AM   #2
Senior Moderator
Parallax's Avatar
What is the maximum aperture of your telephoto lens? The 18-55 by about 50mm or so is only f5.6. If your telephoto lens is faster than that then the image in the viewfinder will be brighter.
04-23-2010, 08:35 AM   #3
Banned
what type of kmount telephoto are you using? what is its focal length and max aperture? is it a manual lens, or is the aperture controlled by the body? the maximum aperture at 18mm is 3.5 at 55 its 5.6, so its likely that the kit lens would be darker, but I cant understand why it would be too dark to focus. maybe the aperture coupling isnt working? when you mount a DA lens, (not sure if this goes for 'A' contact lenses with an aperture ring like FA or DFA) the lens automatically goes to wide open and stays there. look at the front of the lens when its mounted, is it wide open? or is the aperture closed down? when you remove it, regardless of aperture selected on the body, it will close down to the smallest aperture so it should be easy to tell if its not working properly.
04-23-2010, 07:04 PM   #4
QuoteOriginally posted by séamuis Quote
Thanks. I'll take a look at it.
Dan
camera, dslr, focus, lens, photography
St Kilda after Dark knumbnutz Post Your Photos! 14 03-25-2009 06:40 PM
Dark autumn Jimbo Post Your Photos! 6 10-26-2008 11:12 PM
Watch in the dark the_snark Post Your Photos! 1 07-24-2008 06:40 AM
alone in the dark aabram Post Your Photos! 2 02-25-2007 11:14 AM
In the dark BobS Post Your Photos! 3 12-30-2006 12:47 AM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
