Originally posted by jlaubza Marc, I think he means an indication that the correct exposure has been set e.g. a red light turns green or a needle lines up with a mark in the viewing screen (remember Spotmatics?).
Right, and in current models, the thing that provides this same indication is called the "meter" - it reads 0.0 when you have the correct exposure. OK, actually the meter is the thing doing the measuring; the 0.0 is just the "meter display". Whatever, the reason he isn't finding "correct exposure indicator" in the manual is because that isn't the name for it. As I said, you have to be in M mode to see this display, which makes total sense, because in all other modes, you're *always* getting correct exposure (according to the camera). And as noted, you don't see the meter reading normally when using the aperture ring (eg, with K- and M- series lenses), but you can make it display by doing a DOF preview.
