Originally posted by hangu Is this true? I've always thought ISO and noise ratio is strictly a function of the sensor.
You are correct. I think the poster you quoted may have meant "better" lens as in a faster lens, which would let you use a lower ISO for the same shutter speed, resulting in lower noise.
However, the wording is not at all clear. If they meant a more expensive lens will give you better high ISO performance (which would also be an easy interpretation of the post), then they must have gotten some bad information somewhere, as that's quite simply not true.
Quote: If I wanted the best remote, which would it be?
I'm honestly not sure of the "best" remote, but as I seem to recall one of the third-party remotes on ebay that usually ships from asia for about $20 total is preferred by some users over Pentax's own remotes because it has more features or something. Personally, I'd just go for the $2 remote that lets you do bulb exposures more easily.
