04-25-2010, 07:52 PM   #1
AF Adjusting a zoom
i'm doing an AF fine adjust for my zoom.
at 18, it's a bit front focused, at 50 it's a bit back focused.
since you can only do one AF adjust per lens, what would be the best compromise?
should I:
1. set it at midpoint between the front and back focus adjustment values
2. set it at the AF for the long end of the lens
3. set it at the AF for the wide end of the lens
i'd go with #2 since the long end would be more critical to correct focus than the wide end.
what would you do?
jordan
04-25-2010, 08:49 PM   #2
QuoteOriginally posted by opiedog Quote
i'm doing an AF find adjust for my zoom.
should I:
what would you do?
jordan
Where do you use the lens the most? If you use it mostly at the long end, correct it there. If it's at the wide end, correct it there. What I would do though is go ahead with the original idea of #2 and see how it works for the rest. If it's both front and back focusing at the extremes, it would seem to me that in the middle, it's somewhat correct in that range already. No? Yes?
I would also make sure I'm doing these tests in GOOD light (like Sunlight), with a reliable target, at proper angles, not under incandescent or other interior lighting.
04-26-2010, 02:21 AM   #3
blende8's Avatar
You could also send it in for adjustment.
04-26-2010, 06:09 AM   #4
QuoteOriginally posted by blende8 Quote
well, the lenses are not pentax so pentax wont do anything with it.
if i send my lens to sigma, they'll want the body (kx) as well. may be a good idea if sigma can align the lens' AF and match it up with a specific body.
anyone has experience with this?
04-26-2010, 06:30 AM   #5
QuoteOriginally posted by JeffJS Quote
jeff,
yes, the lens seems to be focusing accurately at ~ midpoint. i did the tests using daylight, but like someone once said, i wouln't go crazy trying to get this perfected, since there are quite a few variables involved.
the AF adjustments on the extremes are not so much either +/- 20
i'll do another round of tests and i get the same results, i'll probably just set it to
the AF ajust at the long end.
tnx
jordan
04-26-2010, 08:27 AM   #6
blende8's Avatar
I can only speak for Germany.
It took about 2-3 weeks and the lens was perfect thereafter.
If you have the Kx, you can only apply a global adjustment AFAIK and this only via debug mode. This is not optimal. If your other lenses are ok, then it is probably the Sigma lens and you should send it in.
04-26-2010, 09:38 AM   #7
did you have to send in your camera body?
yes, i have the kx. if i sent it to sigma, i don't expect them to make any changes to the AF adjust on the camera body so i'll set it at 0. they'll probably adjust the len's data parameters for 18 thru 50.
and 2-3 weeks is difficult to be without a camera
tnx
jordan
04-26-2010, 11:14 AM   #8
blende8's Avatar
Yes, with camera.
05-08-2010, 06:16 AM   #9
Class A's Avatar
Wieland, do you have any idea how the adjustment works?
I never found a good explanation as to how two lenses can FF and BF respectively on the same body.
Has it to do with rotating lens elements to minimise abberrations? There's not a lot you can adjust in a lens, is there?
05-08-2010, 08:27 AM   #10
blende8's Avatar
I don't know exactly, but you can program a calibration curve either in the lens and/or in the body.
I know that Sigma can do this in the lens ROM. I don't know about Pentax, but I know that they can program different values for different focal lengths and different distances.
If the standard or factory value does not fit for your body it can happen that one lens shows a BF and another a FF.
05-08-2010, 05:21 PM   #11
Class A's Avatar
Thanks for the info!
Interesting.
af, bit, camera, dslr, focus, front, lens, photography, zoom
Adjusting Camera Sharpness.. cdurfor Pentax DSLR Discussion 7 06-16-2009 10:48 AM
Adjusting Levels and affect on Brightness weaponx525 Digital Processing, Software, and Printing 17 11-09-2008 09:34 PM
Adjusting focus erikro Pentax Compact Cameras 2 07-18-2008 06:20 PM
adjusting power on the AF360 mi2nc Flashes, Lighting, and Studio 2 06-24-2008 11:15 PM
Adjusting saturation in Pentax K100d fevbusch Pentax DSLR Discussion 12 01-27-2007 09:31 PM
All times are GMT -7. The time now is 08:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
