05-03-2010, 07:02 PM   #16
But do I get all the camera's program modes if I set the aperture ring to 'A'? And do I get aperture-preferred semi-automatic, setting it to any other f-stop?
05-03-2010, 07:09 PM   #17
In theory and/or in practice, of these two lenses 18-55mm and 70-200mm, which would be the most in need of auto-focus?
05-04-2010, 02:33 PM   #18
Marc Sabatella's Avatar
With the aperture ring set to "A", all autoexposure modes are available - Av, P, Tv, etc. As well as M, of course, if you like. With the aperture ring *not* set to "A", only "M" works properly, as described in the sticky thread on using manual lenses at the top of beginner's forum.
Not sure exactly what you mena in asking which lens would be in more "need" of autofocus, I but I assume you're asking, which lens would be more vaulable to have in AF form. i'd say the 18-55 would probably be used at least twice as often as the 70-200 - perhaps much more than that. And if you use the 18-55 more, you'd probably appreciate AF more. Also, a telephoto lens magnifies things making MF easier. And it's also more likely to be used in situations like, say, a bird in a tree, where you could never trust AF to choose the bird rather than one of the branches. Add to this the fact that the 18-55 costs next to nothing, but a good telephoto lens might set you back more, and I think it pretty clear.
05-04-2010, 03:02 PM   #19
THanks, Marc.
That was what I was looking for.
18-55mm, 50-200mm, camera, dslr, k-x, kit, lens, photography
Help in purchasing flash kit Sargmaster Flashes, Lighting, and Studio 9 12-15-2009 06:03 PM
Looking at purchasing a used lens Woods12 Pentax SLR Lens Discussion 3 02-22-2008 01:50 PM
Purchasing a k100d.....help chocxfish Pentax DSLR Discussion 1 02-01-2008 12:32 PM
Purchasing k10d Landaris Pentax DSLR Discussion 3 12-19-2007 09:49 AM
K10D purchasing John Pentax DSLR Discussion 42 09-27-2006 08:55 PM
All times are GMT -7. The time now is 02:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
