07-27-2007, 04:59 PM   #16
jeffkrol's Avatar
Since I'm always ready to learn
QuoteOriginally posted by Ivan Glisin Quote
I don't see any problem here, they are all perfectly exposed -- average gray, exactly as it should be. But they just do not look right since camera has reduced the scene to average gray and that does not exactly match your experience. That's what exposure compensation is for.
To better understand what I mean try this: in P mode and any metering mode with AF off (since sharpness it is not important here) take two pictures from a close distance (to fill the frame with a single color) of one black and one white t-shirt, cloth, towel, or any other non-reflective surface. Do not compensate, allow camera to set aperture and shutter speed automatically.
I guarantee you'll be surprised by the result! (You may even think that your camera is broken or that you did something wrong.) Rest assured, everything works as designed. Try this with Canon and Nikon if you wish, or buy a $30,000 digital Hasselblad and you'll get the same result. This can help you understand what had happened with your shots and how to do it better next time.
I'm not sure this one is in any way a "normal" 12% (yes not 18%) grey exposure, though it could be a matrix metering thing. Since monitors can lie (but numbers are somewhat stable)
I tend to use histograms/eyedroppers to confirm what I see. This histogram from this photo is not a happy one....as to the others, I've already thrown my 2 cents in. As a side note I've got those type of exposures w/ my D and did not consider them too unusual, though at times annoying and actualy unexplainable except to center weighted metering being tooo centerweighted. SEE second image..
Note 2: I like them this way, a lot of headroom to adjust, though some worry about noisy shadows and prefer to expose to the right. Someday I'll do it right........
07-27-2007, 08:07 PM   #17
As to the second picture - Despite the rest of the picture being dark, the sky is still totally blown from overexposure. It's not a very large chunk of sky, but it might have been enough to throw off the meter.
07-27-2007, 11:10 PM   #18
Ivan Glisin's Avatar
QuoteOriginally posted by jeffkrol Quote
I think it is. I personally never use matrix metering for two reasons: (1) in general, as a photographer I have no clue what part of the scene is metered by what "cell" in that matrix nor how are all those readings incorporated into a final exposure parameters -- to me it's like a form of gambling and of course the house almost always wins; (2) it appears that Pentax matrix metering is extremely conservative, always pushing everything down unnecessarily at even a hint of highlights anywhere in the scene usually leaving that unused "gap" on the right of the histogram.
I personally use spot meter in manual mode most of the time and I am getting absolutely predictable results with no need to check histogram at all. However, for my style of photography I usually have 5 seconds to do all I have to do in M mode using spot meter mode. This may not work for everyone.
07-28-2007, 12:39 AM   #19
Stop bashing Multi-segment metering
I use it almost exclusively and I can assure you 100% that it doesn't underexpose like this. Such small parts of highlights on the edge of frame like in "table" picture in no way will fool Multi-segment metering. It's much more robust.
In fact K10D tends to overexpose when multi-segment metering is used.
My theory is that either spot metering is used and most often he manages to meter of white subjects or negative EV is dialed in or exposure system is broken and camera needs to be replaced.
07-28-2007, 08:29 AM   #20
Of course. That part was actually not in my comment (somebody else have said that). Small white part is like under 5% of the top "wide" metering cell and I agree it can not affect metering.
Perhaps I should have specified that I have *istDS. There could be differences.
This could be true -- spot metering in auto mode. But, no EXIF provided so we can just keep guessing.
07-29-2007, 07:00 AM   #21
Pentax - dark pictures
Please see the details re my three pictures below:
#1 piture (bird):
Lens: Tamron, 100-300mm, 1:5-6.3
Focal length: 300mm
Shutter speed: 1/750sec
Aperture: F13
Capture mode: Green Mode
Metering mode: Spot metering
White balance: automatic
Sensitivity: 100
#2 picture (garden party):
Lens: Pentax SMC, 18-55mm, 1:3.5-5.6
Focal length: 20mm
Shutter speed: 1/125sec
Aperture: F6.7
Metering mode: Center-weighted
White ba;lance: automatic
Sensitivity: 100
#3 picture (snow):
Focal length: 23mm
Shutter speed: 1/1000sec
Aperture: F9.5
Sensitivity: 100
As you can see first picture was taken with spot metering, the other two with center-weighted metering. The only comon setting of these three pictures is the Green Mode. Don't you think that Green Mode should handle at least the light-related setting such as the correct aperture and shutter speed in order to avoid the under or overexposure? I was alsotaking pictures with built-in flash in the party room with very low light. The results were terrible with almost all pictures too dark. When I compared them with my friend's pictures taken with his Minolta SLR, the difference was evident. I just want to be sure if this is just a problem of camera settings not a technical problem with the camera.
Thank you for all your examples and suggestions. I installed the new firmware, will play with EV compensation and multi-segmented metering. Let me know if you have any other suggestion.
07-29-2007, 08:02 AM   #22
Perhaps this would help
One of my recent posts, apparently helpful to many people:
https://www.pentaxforums.com/forums/post-processing-software/6578-k10d-photo-...html#post54149
The only preconception you'll have to let go here is that camera can take good pictures for you (technically speaking). That's not the case: YOU have to take good pictures, camera is just programmed to give you a starting point, but from there you'll have to take over and finish the job. Thus, you'll have to learn that BOTH your camera and you have to work TOGETHER in order to get good results.
Please do not hesitate to ask additional questions.
07-29-2007, 11:52 AM   #23
QuoteOriginally posted by Maros Quote
#1 piture (bird):
Focal length: 300mm
Aperture: F13
Sensitivity: 100
Focal length: 20mm
Aperture: F6.7
Sensitivity: 100
#3 picture (snow):
Focal length: 23mm
Aperture: F9.5
Sensitivity: 100
It looks like you definately underexposed the first and third shots. Probably the second as well if it was even slightly overcast.
I'm sorry but I am not accustomed to these fancy digital camera meters. I usually just check the meter in my K1000 and then over or under compensate depending on what I think the meter is reading.
camera, dslr, k10, mode, pentax, pentax k10, photography, pictures
Nature On the Dark Side - 5 Pictures Tamia Post Your Photos! 4 11-05-2010 07:31 AM
Dark purple pictures from K-X luma Pentax DSLR Discussion 7 09-20-2010 03:07 PM
Dark pictures sometimes on K20D. jbrowning Pentax DSLR Discussion 18 08-04-2010 08:09 AM
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
Pictures too dark Sargmaster Pentax Camera and Field Accessories 9 12-15-2009 03:53 AM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
