Originally posted by fractal I always use Av mode with my Super Tak. I usually find myself at EV +2 also.
Considering screw mount lenses are MF, I don't think it would matter what setting you had your AF on.
So you're consistently adding two stops over. That's a LOT, and not the case with M mode.
I think you're right about the focus point setting, but since it's only working at a single point anyway, I figure I might as well set it for that.
Because it's not about the AF, but the confirmation, and I don't know how the sensor behaves differently with a manual lens on there. But again, it may make no difference at at all.
