Testing IR remotes with your camera's LV
Posted By: dosdan, 01-27-2012, 04:45 AM
My cheapie multi-camera-brand IR remote control, a "Photon" RC-4, seemed to have stopped working. I remembered that you could test any IR remote with a video camera by actually seeing the IR light, so I tried it in LiveView on a K-5 and found out that the remote has failed.
All the household electronics IR remotes I have here show purple flashing for as long as any button on the remote is pressed, as shown:
A simple tip, but it may be useful.
Dan.
01-27-2012, 10:43 AM   #2
nanhi's Avatar
Dan, it could be a battery problem inside the remote. Normally they use button cells - the larger round ones. On my Pentax F remote it is very easy to change the battery. You need a zero philips screw driver to take the black screws off. The plastic cover comes off. You can see the big round button cell held down by a tiny screw. Remove it, note down the cell model number and buy one from WallMart, Target etc for $ 2 or so. Fitiing back is pretty easy. Just remember the cell polarity before removing from the remote. Good luck.
01-27-2012, 10:55 AM   #3
Most of the cheapies will just have a slide out tray for the battery.
01-27-2012, 01:26 PM   #4
dosdan's Avatar
Battery voltage is the first thing I tested. The button cell measured 3V. The IR remote was cheap. I'll get another one.
The cheap corded remote I've got is nice anyway. It has a mechanical latch to lock down the button which was handy on the K20D in Bulb mode. Now with the K-5 and menu option C.3.19 Remote Control in Bulb you can set 1 press to start and 1 press to stop the long exposure.
With an IR remote outdoors you've got to point at the camera. Operation with a corded remote is more straight-forward and reliable as long as you can be near the camera. I mainly use a remote for long night-time stuff.
Dan.
ir, ir remotes, remotes
Landscape My favorite camera-lens testing area charliezap Post Your Photos! 5 08-14-2011 08:10 AM
People Testing out the new camera Jinxed Photo Critique 5 01-13-2011 08:09 PM
Testing K7 dust seals. Or just how dirty is your camera? Dom Pentax DSLR Discussion 57 07-04-2010 12:56 PM
Testing the camera MsGilbert Troubleshooting and Beginner Help 3 04-02-2010 06:35 PM
Tammy adaptall and camera testing and General Talk 2 10-23-2007 07:25 AM
All times are GMT -7. The time now is 09:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
