Following a recent post by Adam on FB/G+ about view finder magnifiers; I decided with my average eyesight this might be work a go.
So I ordered from eBay a KPS UMC 1.35x eyepiece. It was AU$73.70, it came from South Korea, was ordered on the 29th of December and arrived here in Canberra on the 2nd of January.
How-to.
(Sorry about the rubbish photo's, a friend has my second DSLR at the moment)
Opening the packet, you have 1 eye cup, 1 view finder, 3 mounting plates, a screwdriver, an assortment of screws, and the most useless instructions known to man.
Start by removing the standard eye piece from your camera. My K-5 is pictured here. It simply popped up and off.
Needless to say, the mounting plate that comes attached to the view finder is the Canon one. So start my undoing the two small screws on each side of the glass and remove it.
Next, take the mount marked 'Pentax - Samsung' and place it on the camera where you just removed the standard eye piece, slotting it into the groves.
Now take the new view finder and place it up against the mounting plate. You will find the two of the screws are slightly longer than the rest. I found these the easiest to use here.
With a bit of fiddling, screw the view finder to the mounting plate.
Now simply screw on the new eyepiece
Finally, switch the camera on, focus on something recognizable and re-adjust the the standard focus slider on the view finder.
Review.
Pro's: Makes the view finder significantly easier to see, which I guess is what its meant to do.
Con's: Useless instructions. Useless focus mechanism. Bit pricey for what it is.
I really cant complain about the purchasing aspect of the product. It arrived very quick, however I did pay for express postage. Compared to alternatives it was about 10-15% more expensive.
However on arrival I was a bit disappointed with what I got for $70. Mind you, I dont know what else I could have expected.
I tried to make heads or tails of the instructions, with no joy. They seem to be backwards (I think), however the installation was pretty straight forward and I was able to assemble it myself without any hassle.
The device has its own focusing abilities (in theory). By loosening off a third screw you can rotate the entire eyepiece into focus and then tighten the screw back up. The problem is that it doesn't seem to do anything at all. From all the out to all the way seemed to make no difference in the clarity of the device. *shrug*.
All in all, I'd still recommend this for anyone who doesn't have the greatest eye sight but doesn't like wearing glasses while shooting. I was still able to get enough adjustment out of the built in viewfinder focus to make the new one unnecessary.
7/10
