Originally posted by simon6z I set it on relay mode is ok other than that none works
Don't use relay mode unless you have at least three V6 and want to remote release a camera while using off-camera flash.
I suggest to do a factory reset of the V6 and use M mode or Tv mode so that you can set the shutter speed to something fixed below or equal to 1/180s. Then you'll be able to trigger the flash every time.
N.B.: Also make sure the transmitter (on the camera) is not too close to the receiver (unless you activate the "SHORT" work range in the sub-menu of the V6 transmitter). With the standard "LONG" range setting, too close a distance between transmitter and receiver may lead to radio signal overload and hence stop the receiver from receiving proper signals.
