The right type of M42-to-K-mount adaptor
Posted By: dosdan, 01-18-2010, 05:18 AM
There are two types of M42-to-K-mount adaptor:
  • The Flange type
  • The Recessed type
Don't be like me and get the wrong type, which is the Flange type. While the flange type is cheap, is commonly available and the flange appears thin, it is still thick enough to prevent focus at infinity.
Get the recessed type. I've got a "Roxsen" 3rd-party version. This is very easy to fit on a K100D Super body, but I find it is difficult to fit or remove this quickly on a K20D. The genuine Pentax M42 recessed adaptor is reported to be easier to fit compared to 3rd-party adaptors.
Here's some pictures I took showing the difference between the two M42-to-K-mount adaptors.
Recessed-type adapter plus insertion/removal key on left Flange-type on right. Both showing the side that fits to the camera:
Flange-type fitted:
Recessed-type fitted:
Dan.
03-29-2018, 02:20 PM - 1 Like   #31
QuoteOriginally posted by Theov39 Quote
Good point. No doubt it is just as confusing for them. This particular one was priced quite high so I thought it may have been a genuine.
A copy got stuck on my camera once so I am keen to get a genuine now if I can but the prices for new adapters are just crazy (eg BH Photo are selling them for US$75).
Like I say in my earlier posts in this thread, if it ain't the real one, take that spring off immediately and never look back. If you aren't sure whether it is genuine even after it is in your hands, take the spring off and put it on a body -- the real one will be pretty loose and move around, the fake ones will stay in there pretty firmly even without a spring. (If it is the real one, put the spring back on.) In practical usage, real ones go on the body and stay there, fake ones go on the lens (sans spring) and stay there.
07-25-2018, 11:36 AM   #32
stillshot2's Avatar
Can anyone comment on how much focus is lost with the non-infinity focus-able adapters? For example, will I still be able to focus out to 50 feet away or does it become a strictly macro only lens with such adapter?
07-25-2018, 06:59 PM   #33
QuoteOriginally posted by stillshot2 Quote
Depends on the lens -- 50ft *IS* infinity with many lenses. It is always closer than I want it to be though (with anything that isn't a macro already) so I don't like those adapters, but again, just depends -- with a telephoto you can get 10 or 20ft probably, but if you are trying to focus at near the limit it is just going to annoy you to no end. (Some adapters are thinner than others -- look for a flimsy-looking one if you get one.)
07-25-2018, 10:12 PM   #34
stillshot2's Avatar
Ok thanks. I've also been thinking about readjusting the focusing range of the lens to go past infinity so with such adapter would end right at infinity but I'm not that knowledgeable on how to disassemble lenses in order to do so. I just want a permanent mount for a Takumar 200mm f5.6 and don't like the ones with the removable tabs so much..
07-25-2018, 10:25 PM   #35
Well... good idea to learn to like them -- just stick it on there (remove spring on adapter) and make it a semi-permanent bayonet. I've got at least a dozen like that -- the friction fit is usually more than adequate as long as you don't forget that's how it is attached (and your focus isn't so stiff that it rotates the lens off the camera).
07-26-2018, 07:53 AM   #36
photoptimist's Avatar
The formula for the maximum focus distance is a very strong function of focal length. The formula is:
MaxDist = f*(2+f/∆+∆/f), where ∆ is the flange thickness in mm and f is the focal length in mm
So, if the flange is 1 mm thick, the maximum focus distance for some different lenses would be:
28mm: 2.8 feet
50mm: 8.5 feet
100mm: 33.5 feet
200mm: 132 feet
Note that these numbers change a lot if the lens can focus past infinity.
07-26-2018, 01:02 PM   #37
stillshot2's Avatar
Sadly, the focusing ring on this lens is just a little too stiff for the mount to have a good enough friction fit. I do have two other lenses that work ok with the infinity adapters attached and with the springs removed though.
200mm: 132 feet
Thanks for the calculations! I think 132 feet could be enough for me. May try it out
08-03-2019, 09:11 AM   #38
Oktyabr's Avatar
Don't the flange type short the pins, allowing CIF?
08-04-2019, 05:56 AM - 1 Like   #39
QuoteOriginally posted by Oktyabr Quote
You're right about that -- that's the one shortcoming of the good Pentax adapter. I hat to rig a separate tinfoil setup to short the pins for lenses that didn't do it on their own, like an Industar that was too narrow to touch the pins.
08-04-2019, 08:23 AM   #40
Oktyabr's Avatar
I just bought a Helios 44-2 2/58mm and it's too narrow with an "infinity" adapter as well. Ordered the "wrong" type of flange adapter, which I plan to just leave on the lens, so I can have CIF.
« Camera Bag | - »
adaptor, adaptors, flange, type
New type of generic M42 adaptor? AMBIVALENCE Pentax SLR Lens Discussion 27 05-18-2010 12:25 PM
Need genuine M42 K mount adaptor stonedes Pentax SLR Lens Discussion 12 01-29-2010 12:07 PM
M42 to K mount adaptor eccs19 Photographic Technique 1 10-07-2008 04:14 PM
M42 to K Mount adaptor pentaxk100d Pentax Film SLR Discussion 5 03-11-2008 06:27 PM
All times are GMT -7. The time now is 05:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
