Bringing out the shadow details in a high dynamic range image
Posted By: atupdate, 01-12-2011, 11:03 AM
Many people use dodge and burn to bring out the shadow details in an image. Here is a process that should be a little less time consuming. All processing was done with Paint Shop Pro X but Photoshop will work just as easily.
Here is my original processed from raw so as to keep the details in the water from blowing out.
1) First,I made a duplicate layer and desaturated it using Hue/Saturation/Lightness
2) Then I changed the B&W duplicate layer to a negative.
3) Then you change the blend mode of the duplicate layer to Overlay and change the Opacity to approximately 50-55%. Different photos will require a different Opacity setting but generally it will fall between 40-75%.
Now merge the duplicate layer into the background layer. The image should look kind of washed out. Don't worry, now I'll show you a technique to bring a little pop back to the image.
4) To give the image some pop, I use a double USM process shared by benjikan.Benjamin Kanarek post processing method | PentaxLife
Here are the settings I used. The first USM action was Radius @ 0.3, Strength @ 250, and Clipping @ 0. The second USM action was Radius @ 50, Strength @ 12, and Clipping @ 0. After you run both USM actions, duplicate the layer and set the blend mode to Soft Light and adjust the opacity to what looks good to you (I used 100% opacity on this image).
This duplicate USM layer can also be desaturate and the opacity decreased if contrast and saturation are too strong.
Once you flatten all the layers, you can now tweak the image using layers or curves if you desire. I liked what I saw and went directly to resize.
5) Resize for the web and use USM (Radius @ 1, Strength @ 100, and Clipping @ 3) to sharpen the final image
Feel free to PM me if you have any questions.
Tim
01-12-2011, 12:09 PM   #2
Decent technique. I'd argue that with that image I wouldn't ahve applied any resharpening after the resize for web. downscaling an image tends to make it sharper anyway, and the end result is riddled with sharpening artifacts that I suspect aren't there (or at least aren't as bad) at full size.
01-12-2011, 12:29 PM   #3
QuoteOriginally posted by raz-0 Quote
I think part of what you are seeing is the effect of hosting the images on Photobucket. The final image looked pretty good on my monitor.
Thanks for the feedback.
Tim
01-17-2011, 02:11 PM   #4
Ash
Community Manager
Ash's Avatar
Good work Tim, and thanks for sharing this.
Photoshop does simplify the process with their Shadow/Highlight tool under Image -> Adjustments.
One stop shop for bringing out shadow as well as highlight details.
e.g.
Original
Shadow Amount 30%, shadow tonal width 40%, radius 50px
Highlights Amount 20%, highlight tonal width 30%, radius 40px
change, clipping, details, duplicate, image, layer, opacity, radius, strength, usm
Dynamic Range Extension Shadow Clipping in bokeh Katsura Pentax DSLR Discussion 6 12-21-2009 12:15 AM
High Dynamic Range ve2vfd General Talk 2 09-17-2009 04:03 PM
The Pentax K-7: The era of in-camera High Dynamic Range Imaging has arrived! HermanLee Pentax News and Rumors 2 05-20-2009 10:40 PM
HDR (High Dynamic Range) krs Pentax DSLR Discussion 29 01-09-2009 08:48 PM
High Dynamic Range - How do you do it? MShawn63 Photographic Technique 32 01-11-2008 05:44 AM
All times are GMT -7. The time now is 09:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
