Sigma 8- 16 mm lens correction / metadata in PS & LR - especially at 8 mm
Posted By: beholder3, 02-21-2012, 06:07 AM
[deleted]
03-07-2013, 08:25 PM   #31
bossa's Avatar
hehe that sounds like something Tom or Greg would come out with...
Moss it was.
03-11-2013, 01:56 PM   #32
and you are sure you have also corrected the focallengthin35mmformat?
Yes, I run the bat with the following entries:
"C:\ExifTool\exiftool" -progress -overwrite_original -k -ext dng -ext pef -r "-exif:FocalLength<copy2:FocalLength" "-exif:FocalLengthIn35mmFormat<Calc35mm" -if "not $FocalLength ge 10" "%1"
After this I actualized the metadata in LR - the focal length is now displayed well, but not the lens model.
Then I ran the LR-plugin from this site:
DigitalFotoNetz.de :: Thema anzeigen - Sigma 8-16 Brennweite < 10mm in EXIF vorhanden
Everything is now displayed well, the lens model and the focal length. But nothing happens when I start the lens correction.
03-11-2013, 03:42 PM   #33
[deleted]
03-11-2013, 11:43 PM   #34
QuoteOriginally posted by beholder3 Quote
We are talking about a RAW picture?
Yes, of course. Itīs a DNG file from my K20D
So you see the corrected focal lengths in LR?
Yes
And you check the profile corrections activate checkmark?
Yes
And you have chosen Make "Sigma" + Model "Sigma 8-16..." + Profile "Adobe (SIGMA....)"?
Yes
And when you toggle the checkmark the picture doesnt change at all?
No, when I toggle it on and off, there is no change...
03-12-2013, 01:50 AM   #35
[deleted]
03-12-2013, 10:22 AM   #36
Sigma Lenses in Lightroom 3.6
Hello,
I have 2 Sigma lenses: 8-16 mm and 150-500 mm.
In LR 3.6, the first didn't show focal length when >10 mm. The bat file above solved my problem, but:
1) didn't show Lens Model in LR show info, but focal length only;
2) LR lens correction is not automatic: I must select "personal profile", then select manually the lens profile (8-16 or 150-500).
I built a batch file assembling the 2 command lines wrote by Beholder3:
"d:\Program Files\Utility\exiftool\exiftool" -overwrite_original "-exif:LensModel<makernotes:LensType" "-XMP:Lens<makernotes:LensType" "-exif:LensInfo<LensID" "-exif:LensMake<LensManufacturer" "d:\pictures\test"
"d:\Program Files\Utility\exiftool\exiftool" -progress -overwrite_original -k -ext dng -ext pef -r "-exif:FocalLength<copy2:FocalLength" "-exif:FocalLengthIn35mmFormat<Calc35mm" -if "not $FocalLength ge 10" "d:\pictures\test"
Running this bat file, LR 3.6 shows both Lens Type and Focal Length < 10 mm. but:
a) problem n. 2 is still open: I must assign manually the right lens profile (Sigma 8-16 or Sigma 150-500)
b) the first command line, when runs, shows this error: "warning: not enough values specified (4 required) for ExifIFD:Lensinfo"
Can you help me solving a) and b)?
Thank you.
03-12-2013, 11:47 AM   #37
[deleted]
03-12-2013, 12:12 PM   #38
a) there is no solution I know of. I always choose the profiles manually. Takes only a second.
b) this is just a warning because some data is missing in the exifs, it is no error and does no harm. The field LensInfo required four input values and for some lenses these can not be derived from other data. You can fill them manually if you wish. lensInfo requires the focal length ends of a lens and the apertures at these ends, so for a 50/1.5 it is "50 50 1.4 1.4" and for a 35-80mm F3.5-5.6 it is "35 80 3.5 5.6".
many thanks for your quick answer, Beholder3!
03-13-2013, 10:12 AM   #39
I donīt understand why it doesnīt work.
Here are two screenshots, perhaps anybody can see my mistake...
03-17-2013, 03:21 AM   #40
Hmm, I just dumped all metadata from an image taken with my K30 using the Sigma 8-16mm and I don't see any focal length values in the Makernotes.
Aside from SR Focal Length it seems all focal length data is 0mm :-(
04-14-2013, 12:19 PM   #41
newmikey's Avatar
Late to the party but picked this up and all I can say is THANKS!!!
I just incorporated it into a little bash file that can quickly parse through an entire directory:
#!/bin/bash
let "nbfiles = $# -2"
ref=$(kdialog --title "UFRB-KDE" --progressbar "(Initialising ...)" 15)
qdbus $ref Set org.kde.kdialog.ProgressDialog maximum $nbfiles
count=0
for i in "$@";do
if [ -f "$i" ];then
let "count +=1"
exiftool exiftool '-exif:FocalLength<copy2:FocalLength' '-exif:FocalLengthIn35mmFormat<Calc35mm' $i
qdbus $ref setLabelText "ExifTool - Updated Sigma 8-16 file: `basename "$FILE"` ($count of $nbfiles files)"
qdbus $ref Set org.kde.kdialog.ProgressDialog value $count
fi;
done
qdbus $ref close
06-19-2014, 03:10 AM   #42
Hi
I just received an Sigma 8-16, and as some might be interested, I just post that this command works for me in Terminal of MacOSX (with exiftool installed, of course):
QuoteOriginally posted by cali92rs Quote
exiftool "-exif:FocalLength<copy2:FocalLength" "-exif:FocalLengthIn35mmFormat<Calc35mm" MYIMAGEFILE.DNG
Cheers - Klaus
06-19-2014, 03:15 AM   #43
I ought to mention that Rawtherapee handles data for this lens fine with the current release
06-19-2014, 07:57 AM   #44
cali92rs's Avatar
QuoteOriginally posted by damianc Quote
As does PTLens...you just have to input manually the focal length for 8 and 9 mm
06-19-2014, 08:01 AM   #45
Don't they all "handle the data" just fine if it is there? Problem is the data is not there -- camera doesn't output it...so you have to add it to the RAW files.
mm
More ??? About lens correction & anti-shake CDW Pentax K-5 5 06-08-2011 12:09 AM
Adjusting Lens descriptions in metadata lats Pentax SLR Lens Discussion 2 10-31-2010 11:16 PM
K-7 Hightlight Correction & Shadow Correction & Raw Christopher M.W.T Pentax DSLR Discussion 6 06-10-2010 03:32 PM
For Sale - Sold: Sigma EX DG 100-300mm/4 &amp; Metz 48 AF-1 Flash &amp; Adaptall P/KA w/ 28mm 2.5 lens OrenMc Sold Items 15 04-15-2010 03:30 PM
Lens Metadata in Lightroom Pentaxke Digital Processing, Software, and Printing 5 03-19-2008 09:14 PM
All times are GMT -7. The time now is 01:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
