I recently posted a
tutorial on conversion of colour negatives with GIMP 2.10 and RawTherapee 5.8, using RawTherapee's Colour Toning tool to remove the film base colour cast.
Fellow forum member @jbinpg (Jack) informed me that Darktable has the same or similar colour adjustment capability in the form of its color correction module. I've now figured out how to apply this such that it achieves the exact same result as in RawTherapee. The method is basically the same, but with one small wrinkle, which is easily dealt with... Good news for forum members who'd like to try this negative conversion approach but prefer Darktable as their raw converter.
Here, then, is a condensed tutorial for the Darktable variation of the process. Please read it with reference to
the original tutorial, replacing the RawTherapee steps with those below.
GIMP should be configured to use Darktable for importing and converting raw files.
After opening GIMP and loading the negative DNG file, the Darktable plugin is loaded. De-activate all optional modules except for white balance (output color profile, input color profile, demosaic and raw black/white point are permanently activated):
In the input color profile module, set input profile to standard color matrix; working profile should be left at the default of linear Rec2020 RGB; gamut clipping set to off:
Set white balance to camera:
Increase the reproduction ratio to 100% and navigate to an area of the photo's border. Select the color picker drop-down and click on the eye-dropper:
Place the colour picker on the border area. The current (R)ed, (G)reen and (B)lue values will be shown in the color picker drop-down:
As in the previous tutorial, the aim is to adjust the image until these R, G and B values are equal or close to equal.
Activate the color correction module. Click and drag the dot to adjust the balance of R, G and B values. Moving the dot LEFT increases the (G)reen value and decreases the (R)ed simultaneously, while moving it RIGHT increases (R)ed and decreases (G)reen. Moving the dot UP increases (G)reen and decreases (B)lue, and moving it DOWN increases (B)lue and decreases (G)reen:
Darktable's color correction module doesn't have the range of adjustment offered by RawTherapee's Colour Toning tool. Here, I've equalised the G and B channels at 207, but I've run out of range for R at 245 - I can't move the dot further to the left, and hence can't reduce the R value
The solution is to create a
new instance of the color correction module, and continue the adjustments in this second instance, which has a cumulative effect on the first:
The R, G and B values are now identical. When Darktable is closed, the image will be transferred to GIMP for the rest of the workflow, as per the previous tutorial.
I hope this is helpful to those who prefer Darktable. The adjustments are just as effective and accurate, and in fact a little easier to make, since the color correction module is less sensitive to mouse movements than RawTherapee's Colour Toning tool.
Both RawTherapee and Darktable variants of the process produce near-identical and wondefully-accurate colours in final positive images
Have fun
