making a flash puffer out of an old film container
Posted By: lguckert79, 02-24-2011, 01:29 PM
step 1: well you get an old film container "white one" it is very important that it is the white one.
step 2: you measure your pop up flash.
step 3: you mark the old film container to the measurements of the pop up flash remember not to cut the end with the lid you need the lid to be able to still go on the container.
step 4: you use either an xacto knife or a small razor blade and cut the measured your area out of the container, make sure that you cut it enough to fit over the flash its self.
step 5: glue the cap on and let dry then try it out
mine works great and i saved 20-40 bucks that can go for a new lens or what ever
ps if you have a bigger flash that conects to your camera youy can do the same thing with a bigger old mild jug a one quart jug if it is white plastic .
02-24-2011, 04:52 PM   #2
SpecialK's Avatar
QuoteOriginally posted by lguckert79 Quote
How about toward a new flash? I got one that bounces, swivels, manually zooms, has 2 auto modes and a M mode for under $40. Of course the film can has the size and weight convenience, but for increasing the IQ I think an adjustable flash would help. Plus, you can paint buildings (or other things) with light during long exposures....
02-24-2011, 11:39 PM   #3
Shouldn't this be in the DIY section?
02-25-2011, 07:26 AM   #4
lguckert79's Avatar
your right adam sorry ill try to move it, but do we have a "DIY" section and if we do how do i move it?
02-25-2011, 08:55 AM   #5
Ira
Why measure and glue the lid?
I would just cut a slit in the button, slide it on, and pop on the lid.
You can also use black tape on the rear so you don't lose any light in that direction when it's bounced back.
02-25-2011, 01:09 PM   #6
Jasvox's Avatar
I made something very similar to this, only using a ping-pong ball. Works great!
Jason
02-25-2011, 01:55 PM   #7
Looks like it magically happened
02-26-2011, 08:45 AM   #8
lguckert79's Avatar
thank adam
03-13-2011, 09:58 AM   #9
I've done this, and it does work well. I've made a further mod though, I attached a piece of 2.5cm double sided tape to a stip of fine-diamond textured mylar, and then stuck it on one side of the slot. Now I have a diffuser with the can attached one way, and an up-lighter when it's the other way around. It prevents red eye and gives a smoother light spread. Obviously, if I know I'm going to be using a flash I'll take my external with me, but the film can is so small, light and cheap that it lives in my bag for those times when I don't have it.
Oh, and I've been wondering why the built-in flash doesn't swivel in its housing, would be a feature that'd get used a lot I reckon.
03-13-2011, 11:57 PM   #10
lguckert79's Avatar
that is a good idea and the swivel flash in the housing flash sounds good
03-14-2011, 12:06 PM   #11
pacerr's Avatar
Or, Jumbo-size it!
Half gallon (1.8 ltr) jugs work for the larger flashes. Foil lining to concentrate the light as desired. Trim the bottom correctly and the "cap" just snaps on. Shown with AF-360.
H2
05-02-2011, 11:15 AM   #12
lguckert79's Avatar
that is a great idea i love it cause i have a swivel flash well and old one that works on my dslr and i have been thinking of some sort of a diffuser and this is great thanks
container, diy, do it yourself, film, flash, jug, lid, pop, step, yourself
DIY: Making a Flash Bouncer tcdk Do-It-Yourself 25 02-09-2011 08:13 AM
Think FILM... technology is making us lazy! rburgoss Photographic Technique 53 02-21-2009 12:46 AM
"puffer" flash diffuser jjfdvm72 Pentax DSLR Discussion 1 03-24-2008 02:51 PM
Making some use of onboard flash pentagor Flashes, Lighting, and Studio 10 02-27-2008 01:24 AM
some 2:1 and a 4:1 macro (flash making it much easier) rhermans Post Your Photos! 5 07-15-2007 04:55 AM
All times are GMT -7. The time now is 04:53 PM. | See also: NikonForums.com, part of our network of photo forums!
