Co-axil -pod adapter
Posted By: pacerr, 05-29-2014, 09:35 AM
(OK, co-axial . . .)
Lookin' to find something to facilitate various comparisons between bodies or lenses I fabricated this dual body-mount bar in about an hour from the scrap bin. No dimensions are critical other than adequate spacing to clear all bodies that might be used. Body/lens foot attachment methods depend on use.
I'd select materials and methods suitable for at least a balanced 10-12 pound load.
05-29-2014, 11:05 AM   #2
carrrlangas's Avatar
Looks awesome. What do you use it for?
05-29-2014, 11:12 AM   #3
crewl1's Avatar
You have aluminum scrap!? You must work some cool projects.
One suggestion I might make is to have the camera attachment point an elongated hole that will let you move the camera fore and aft if sensor alignment point is critical for your comparisons.
Look for the -0- sensor plane indication mark on the body.
05-29-2014, 07:48 PM   #4
pacerr's Avatar
QuoteOriginally posted by crewl1 Quote
if sensor alignment point is critical (index on) the -0- sensor plane indication mark
Interesting point. Many modifications are possible depending on the use. I'll likely enlarge the screw head access holes on the bottom for convenience.
At present, I'm just playin' around with co-axial lens convenience and usin' an IR remote to trigger both bodies simultaneously. .
A single strobe with a predetermined, manual exposure may serve for both bodies if desired.
Re: comments regarding 3-D possibilities - exact placement is dependent on the lens tripod foot unless using the camera mount. Obviously it's best to use identical bodies and lenses.
bodies, diy, do it yourself, methods, yourself
DIY Odd Pod for Macro and Lightbox DeepThrob Do-It-Yourself 6 04-14-2015 03:15 PM
Co-axial adapter pacerr Pentax Camera and Field Accessories 7 05-31-2014 05:35 AM
_disk_id.pod Steve.Ledger Troubleshooting and Beginner Help 3 02-20-2014 08:39 PM
Handmade walking stick/mono pod combo Griz57 Photographic Industry and Professionals 8 10-26-2012 05:26 PM
Sand + tri pod legs = PITA mattt Troubleshooting and Beginner Help 9 08-21-2012 10:05 PM
All times are GMT -7. The time now is 11:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
