9 Likes  #1
K-5 Full spectrum conversion (IR filter removal)
Posted By: Azergoth, 06-30-2017, 09:48 AM
Hi all :-)
Too long, didn’t read: here is the time lapse!
I have not found any information on "the internet" about the full spectrum conversion of 'recent' Pentax cameras. So here is a little feedback.
Firstly, what is a full-spectrum conversion and why should I care? You might know (or not) that camera sensors are sensitive to infrared light (IR). But as the human eye is insensitive to these wavelengths, camera manufacturers install an IR-cut filter in front of the sensor. There are some exceptions, such as the Canon 20Da, 60Da and Nikon D810A, but this is a minority. The Canons are obsolete and the D810A… well… I want one but I can’t afford it! and it’s way less fun!
… so, why should I care? There are two domains in which this filter is an issue. Infrared photography and astronomy. I have never done IR photography, but it seems fun and you can easily understand why an IR blocking filter in front of the sensor can be problematic. My main interest lies in astrophotography: nebulae do emit light in the very far-red spectrum (Hydrogen alpha) and this light is mainly blocked by this filter. This is why removing it yields much better images! This is why I tried (and succeeded) to remove this annoying filter.
But why Pentax? There are hundreds of tutorials for Canon, it is easy and well documented and tethering is supported! (Yes Pentax! I’m mad at you!!). Just because of the sensors! (and also because I found this bargain!)
First, what you need to know:
  • You might damage some functions, be careful!
  • You WILL lose phase detection autofocus
  • Focus to infinity might be a problem with some lenses (!)
  • Obviously, the color rendering will be totally screwed up! Even a custom white balance would not help!
  • Obviously, you will lose warranty and you play at your own risk!
This isn’t full tutorial, as I had no idea what I would find inside, so I’m unable to write a full step-by-step tutorial with pictures. However, here are some key points:
  1. Be aware of the risks you are taking. This has taken me several hours… And there are a lot of different screws! Work on a big table in a clean environment. Take pictures to know how to reassemble the camera.
  2. Required tools: small screwdrivers, little (ing) IMPERIAL (!!) Allen wrench, tweezers, storage boxes or bags (a lot of different screws), a small soldering iron and some skills (intermediate or good, definitely not beginner)
  3. Start by removing the lower cap of the body, super easy !
  4. Removing the back is somewhat trickier. You have to use a flat screwdriver between the back and the front plate. Start left (seen from behind) and then right. Removing the top assembly might help (see later). There are two lids on both sides of the viewfinder. The back plate has to slide downwards in order to be removed.
  5. It’s not yet mandatory to remove the top assembly, but if you want to do it right now, there is a screw hidden behind the rubber part next to the AF selector. Also, don’t forget the screws in the flash… It’s one full assembly, so be careful not to damage the wires.
  6. Once you have removed the back cover, you will see the green motherboard. The sensor is right behind and you can see/hear it move.
  7. Removing the card seems mandatory to access the sensor. Maybe it is possible through the other side, but I have my doubts!! I had to desolder all the little cables at the lower right-hand side. Be careful to know which goes where for reassembly. Take also care of the routing of those cables.
  8. At this stage, it is necessary to remove the upper assembly to access the sensor block. It is maybe not the case I you choose to desolder the upper cables.
  9. Lift the green motherboard and you will have access to the screws holding the sensor assembly. There are little blocking screws which you can remove with a screwdriver. The other screws are spring-mounted Allen screws and are sealed in glue. You can remove those screws but be aware that those screws are used to keep the sensor parallel to the lens mount and probably used for calibrating the phase detection AF. I tried to note how many turns were needed to unscrew them, but as their pitch was very small, I didn’t notice exactly when they were unscrewed. It was something between 10 and 13 turns.
    EDIT: The main mistake you (I) made is unscrewing 3 glued Allen screws from sensor block. It is better to screw them completely to the end first and to measure how much rotations you need. Thanks Medex (here below!)
  10. You now have access to the sensor assembly. It is not very easy to remove, but it’s ok… There are two screws to remove the filter holder. Between the filter(holder) and the sensor lies a thin square plastic window which I placed back upon reassembly. I’m not sure if it is possible to remove the filter from its holder without damaging it or its holder. There are in fact two laminated (glued) filter: the IR filter (just on top of the sensor) and a clear (low pass ???) filter with the piezo strips attached to it. I don't think it is possible to separate those two filters, so braking it (as I did) is not an issue. I also cut the piezo wire, by the way. Tis allow not to damage the filter holder (too much). This filter could (?) however be replaced by an Astrodon or Baader filter in order to take pictures ‘in daylight’ and to keep the PDAF functioning. One should then take care of filter thickness AND sensor reassembly (for PDAF)!!
  11. The sensor assembly and reassembly is not very easy to handle as it wobbles in the SR mechanism! But it's fun! Just be patient and use tweezers. Try to keep the sensor clean!
  12. Now reassembly! It's way less fun than reassembly! There are two tricky parts:
    1. The sensor assy should be calibrated. As I didn’t know of how many turns I unscrewed them, and more importantly because the filter was removed, I just screwed them back to their maximum. It was about 15 turns. I still have to investigate it, but the sensor plane looks good!
    2. Resoldering all the tiny wires. Just be patient and be careful about which one to handle first! Be also careful for the cable routing.
Some conclusions:
I wasn’t very confident, but it’s a big success! It’s not as easy as a Canon, but it’s certainly doable!
The sensor seems parallel to the mount, so no out of focus parts. Still have to test on a dark sky, though!
PDAF is, of course, lost. And there is no contrast detection AF. That’s a little disappointing!
I have lost infinity focus on the 35 mm f/2.4; an UV filter does not help.
Infinity focus on the 100 f/2.8 macro is still ok but by a hair! It's also ok on the Sigma 17-50 f/2.8 (zoom lenses should be fine, in genreal)
I have to test on other lenses (sigma 50 f/1.4, Pentax DA* 300 mm f/4) ! In general, lenses without some headroom past the infinity mark might be problematic.
06-30-2017, 11:49 AM - 1 Like   #2
Firstly, I really admire your courage in attempting this. I remember my first steps into lens servicing were fraught with worry, but this looks absolutely terrifying by comparison!!
Secondly, I'm amazed at just how much is squeezed inside the K-5 (and, I suppose, any DSLR). Quite a feat of design and engineering!!
Very well done, and thanks for posting this. Most impressive!!
06-30-2017, 02:13 PM - 1 Like   #3
Thanks for your comment
06-30-2017, 03:20 PM   #4
ripper2860's Avatar
Thank you, but I'm out ...
This requires skills well in excess of my abilities. And it requires tools to boot.
Yo. Envy of your mad skillz! (Sorry -- been watching Breaking Bad again, and I'm starting to fall into Pinkman-speak.)
06-30-2017, 05:03 PM - 1 Like   #5
jumbleview's Avatar
Used K-5 could cost $250 ... 300. Very tempting, especially having your tutorial. I tried IR photography with IR filter R72 on non-modified camera. Seems to work but require long exposure. I will play a little more to see if it what I like to do. With IR removed probably exposure time should be normal, right?
06-30-2017, 10:07 PM   #6
Nice work. Looking forward to your astrophotography results.
07-01-2017, 12:18 AM   #7
QuoteOriginally posted by jumbleview Quote
Maybe not 'normal' but certainly much shorter than without the mod 😉
Don't forget you might lose infinity focus on some lenses!
07-01-2017, 02:46 AM - 1 Like   #8
Medex's Avatar
Hi,
nice to know about such big enthusiam in modifying Pentax cameras.
Three days ago I completed modification of my Pentax K-5 to IR spectrum (640 nm) camera. This was second modification done by myself, first was in autumn 2016, Pentax K-30. So, I have a little experience and can say, that focusing to infinity is possible even using PDAF. CDAF also definitely. I wrote complete modification guide, but it is in lithuanian language
Pentax K-30 modifikavimas ? infraraudon?j? spinduli? kamer?
I used 640 nm IR filter in both cases. It is 2 mm thick and provide some refraction that allows you to calibrate sensor block to achiev infility. For astrophotography and infinity focus you can use special clear filter, e.g. provided by Kolarivision. Maybe there are special hydrogen alpha filters.
The main mistake you made is unscrewing 3 glued Allen screws from sensor block. It is better to screw them completely to the end first and to measure how much rotations you need. In my K-5 left bottom screw needed 2 and 1/3 rotation, right upper screw 2 and 2/3 rotations and right lower screw 1.5 rotations.
After installation of 2 mm 640 nm IR filter I needed to make additional unscrew of Allen screws 1.5 rotations to achieve NORMAL infinity (on the infinity mark of the lens, not on the 0,7 m mark ). In K-30 camera - 2 rotations. These allow to move sensor block a little apart from lens mount and then you can achieve infinity. How much you should unscrew depends on refraction of the newly installed filter. I used 14 mm Samyang or 18-35 Sigma Art for the control of infinity.
After this step you need to calibrate PDAF. There are 3 Allen screws in the bottom of the camera. You need just 1, that is more proximal to the lens mount of the camera. For IR filter installed on K-5 I needed to rotate that screw counterclockwise. If you want to use just 1 lens for astrophotography, calibrate just for it. If you want use different lenses (in my case 14-100 mm range), use for the calibration of PDAF 50 mm lens. After that make Fine focus adjustment (-5 for Sigma 18-35, +5 for FA*85 f1.4, +10 for FA 100 f2.8 macro - I used these lenses). For samyang 14 mm I needen no focus calibration because it is manual focus lens
BTW, I also unsoldered (not cut) dust removal contacts from sensor block. Now I realise, that there is possibility to dissasemble Hot mirror ant clear filter with piezo strip and in case of very clear environment to use latter to safe dust remowal function of the camera.
Good luck in the process of modification!
07-01-2017, 06:45 AM   #9
dasPaul's Avatar
nice and thanks for that insight, it came 4 years to late for me . Back then I sent my K5 to "Spencers Camera" from Germany to the US. That was very painfull but after 4 or 5 months or so of waiting without communication and putting me off I got a working full spectrum camera back. Nowadays I would definitely try by myself. I did a Canon EOS700D full spectum modification without any issues. I sold my modified K5 some years ago (for a quite good price) due to the lack of libgphoto2 support and changed my astrophotography cam to canon.
07-01-2017, 08:24 AM   #10
QuoteOriginally posted by Medex Quote
Hi,
Thanks Medex for your message! You are absolutely right about the screws! I should have known better! I've included your comments in my post.
I didn't know about Kolarivision, but it seems very interesting! I only knew about Astronomik and Baader... but I don't know yet what I will do about a filter. And if I try to put one in front of the sensor or in front of the lens... I need the Ha line at 656,3nm but it would be nice to cut the IR beyond that...
10-22-2018, 08:26 AM   #11
Quick test from last summer:
10-22-2018, 10:41 AM - 1 Like   #12
smigol's Avatar
Congratulations on this work! Since the sensor floats for the shake reduction, there's not an easy way to add a cold-finger for astrophotography work.
Regarding the filters, I would suggest looking at the IDAS HEUIB-II filter for modified cameras. It does not work directly on the sensor because of reflections within the filter, but it works very well on the end of the lens.
Another filter that works well for full spectrum cameras is the B+W 486. It allows the Ha wavelength through (without NIR) and has a hard cutoff above 400 nm, helping to reduce purple halos around stars.
I've used the 67 medium format lenses with the kmount converter and played with filters within that assembly (I think a 52mm filter screws into threads inside). This allows experimentation with different filters and the impact on infinity focus.
06-16-2019, 02:47 AM - 1 Like   #13
Fantastic work. Much more complicated than replacing a solenoid.
Because you have mentioned that you have not found any information on "the internet" about the full spectrum conversion of 'recent' Pentax cameras:
I found one for the K-30 on a Lithuanian website. I don't understand a word but the photos show a well documented process:
06-16-2019, 07:40 AM - 1 Like   #14
QuoteOriginally posted by photogem Quote
Thanks!
I had *not much to lose* Worst case, it was about 190 euros for a couple of hours of fun. Not cheap, but I can could live with it.
I see the K30 does not require to unsolder, which is a great advantage. I dont remember if it has 12 bit raws and how it behaves in low light. For astronomical pictures, this is very important (even though the K5 starts to show its age...).
If I had to do it again, id be more careful about sensor alignment and tilt. Im very lucky to have none. Also, infinity focusing is lost on some lenses, which could be an issue.
Last but not least, in astrophotography, IR seems to smear out stars, so an IR blocker (beyond 656 nm, if my memory is correct) would greatly help.
06-16-2019, 11:12 AM - 1 Like   #15
Dale H. Cook's Avatar
That is an excellent tutorial. You obviously understand the importance of photographs and notes in making sure that you can put complex equipment back together. That conversion could probably be done to a number of used cameras that are now available for reasonable prices. As one with extensive experience in a variety of finicky non-camera mechanical and electronic modifications I have a few suggestions for folks who might want to try this operation on this or another camera:
1) Some of the mechanical disassembly and reassembly might be more precise with the aid of a very low range torque wrench. I use a CDI Torque 0-30 inch-pound wrench with a bi-directional analog dial and a follower needle. The follower needle marks the torque required to break a fastener free, allowing me to tighten it to the same torque during reassembly. Note, however, that an American-made tool like mine (with calibration certificate) will cost $75 USD or more.
2) Mechanical reassembly might be more satisfactory if one could remove any unneeded optical element from its frame and re-install the frame. If that is not feasible it might be a good idea to use shims (such as washers) in place of any part of a removed item through which fasteners pass. Decent quality digital calipers are relatively inexpensive and would allow shimming to the same thickness as the removed part.
3) Documentation is paramount for a successful reassembly. I do this with a DIY mount that suspends my K-70 above and pointing down at my bench. I use WiFi Commander for Pentax to remotely control the camera. I have a system of annotated storage for removed parts, and take copious notes on the SD card of my pocket voice recorder.
A couple of years ago I participated in a discussion elsewhere with folks who wanted to take better IR photos at low cost for DIY research. I will point them to this thread.
access, astronomy, care, conversion, diy, do it yourself, filter, full spectrum, fun, holder, infra red, infra-red, ir, mod, modification, pentax, screws, sensor, spectrum, yourself
Full spectrum converted K-01, bought new lens, IR filters not working annalisa Pentax K-01 11 08-06-2017 06:37 PM
K-30 full spectrum conversion eye Pentax K-30 & K-50 12 11-14-2015 04:21 PM
Nikon D70 Full-Spectrum IR Conversion AquaDome Canon, Nikon, Sony, and Other Camera Brands 0 01-18-2014 11:45 AM
The Yellow Brick is going out for a full spectrum conversion. VoiceOfReason Pentax K-01 11 10-08-2013 02:00 PM
All times are GMT -7. The time now is 06:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
