Cheap bench top power supply
Posted By: Altheim, 03-02-2018, 06:01 PM
I recently picked up an *ist DL body that was listed as broken/for parts due to a the flashing battery battery issue that seems to be common. The owner could not tell me if anything else was wrong since he could not get the camera to turn on. I bought the unit to scavenge for another unit but wanted to find out how functional it was before anything else. I putz around with low voltage electronics and had a variable 1-12v DC Chinese power supply kit that I got on the Bay for $11.00 that I thought would do the job.
I then dug through my miscellaneous plugs and found a .187 dia. female plug from a universal kit I got at some point. After confirming the plug polarity I soldered on leads made from a roll of doorbell wire I use for this type of thing. A little shrink tubing and a twist in the drill and I was good to go.
The power supply is a little light on the current side and you need to have batteries in the unit to avoid excessive draw. But it does hold a pretty steady 6.5 volts unless you start running through menus and then there is a drop but not so much the unit shuts down.
I was able to get the unit up and test all the functions. Turns out it was fully functional and just needed the battery terminals cleaned up!
Total cost was probably less than $15.00
03-03-2018, 02:52 AM   #2
Wasp's Avatar
Nice one.
I have never seen a camera connected to a bench power supply before!
03-04-2018, 07:50 AM   #3
That's great, thanks for sharing.
03-07-2018, 07:39 AM   #4
awesome! now make it ring a doorbell for af lock
*ist d series, battery, bench top power, diy, do it yourself, kit, plug, power, unit, yourself
Help wanted: just changed power supply/ad RAM: 15 GB of SSD storage are gone ! ??? jpzk Troubleshooting and Beginner Help 30 05-09-2017 07:02 PM
Pentax external power supply voltage tolerances beholder3 Pentax DSLR Discussion 9 02-16-2017 05:56 AM
DIY K-5 Power Supply from 12V battery atnbirdie Pentax K-5 19 12-14-2012 10:18 AM
Possible DIY portable Power Supply for Studio Strobes - ADVICE NEEDED MRRiley General Talk 4 09-11-2008 05:40 PM
Charger/Power Supply jnorth Pentax DSLR Discussion 15 01-07-2007 10:47 AM
All times are GMT -7. The time now is 08:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
