DIY K-70 L-Bracket
Posted By: Dale H. Cook, 05-23-2019, 02:19 PM
Necessity, it is said, is the mother of invention. I wanted a sturdy L-bracket for my K-70 with Manfrotto RC2 plates. Manfrotto makes a nice one already equipped with RC2 plates, but I am (mostly) retired so I was not about to spend $140 for their bracket when I am saving up for more expensive photographic toys. I looked at a number of aftermarket brackets but putting RC2 plates on them would be a chore. I finally built my own with the help of a friend who has a machine shop filling his garage (his Lexus has to sit out in the rain). It is built with 1/4" aluminum bar stock and that strikes the right balance between light weight and ruggedness. It clears the mic/remote shutter port so I can still use that, and is small enough to comfortably fit in my camera bag. Details are available on my web site.
05-23-2019, 03:22 PM - 1 Like   #2
QuoteOriginally posted by Dale H. Cook Quote
Sounds like about the proper trade-off. I keep telling my wife "If somebody offers you a milling machine, the answer is 'YES' "!
05-23-2019, 06:45 PM   #3
Dale H. Cook's Avatar
I have a very well equipped electronics shop in my house, and my Explorer is in effect a well equipped electronics shop on wheels for work. I am moderately well set for woodworking at home (I used my table saw earlier this evening), but I am not set up for machining. My friend has a milling and boring machine, a machine lathe, a heavy-duty drill press, a metal brake, and all sorts of other machine tools. It is good to have well-equipped friends.
I like DIY. I am most of the way through a DIY project of getting equipped for a try at taking professional quality gravestone photos with a specially equipped off-camera speedlight. Old gravestones face east, and in order to have the face of the stone sunlit in such a way that the carving is in optimal shadow photographers have had to work in a window just before the sun reaches the zenith when it is at a 20 to 30 degree angle to the face of the stone. The hardest part of using a speedlight to light the stone at the proper angle is in overcoming the inverse square law.
06-03-2020, 02:53 PM   #4
Wingincamera's Avatar
Thank you Dale for the L Bracket design. I reposted this to the KP forum board, it's hard to find any L Brackets for the KP without having to order them first to see if they will work, or require alterations.
diy, do it yourself, k-70, l-bracket, manfrotto, plates, rc2, yourself
L Bracket With Ball Head or No L Bracket C_Jones Pentax Camera and Field Accessories 8 01-04-2016 05:02 AM
DIY Flash Bracket OrangeKx Do-It-Yourself 9 08-01-2012 03:57 AM
Cheap or diy bracket for softbox? pete_pf Flashes, Lighting, and Studio 11 07-27-2011 02:47 PM
DIY Ring flash bracket tcdk Flashes, Lighting, and Studio 2 05-11-2009 02:09 AM
DIY Portrait Bracket filmamigo Pentax Camera and Field Accessories 3 12-06-2007 11:15 AM
All times are GMT -7. The time now is 01:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
