The ON-OFF-Switch and the Shutter-Release-Button are pretty similar on all Pentax-bodies
(KP is different though but I haven't inspected a KP yet and touch wood, I won't have to)
*K-S1 is different in size but same principle
For this manual I used a heavy used switch/button from a Pentax *ist-DS.
Disassembly should be clear, if not, check on the
other tutorials I wrote!
Once you have access to that part, it looks like this:
1. Unscrew and take off that part with
3 pairs of "contact-bushes" (and don't bent them at all!)
RED ARROW:
2. Unsrew and take of that
round boomerang-shaped part GREEN ARROW:
Don't lose that tiny ball at the long end of this part, it is just fixed with some grease on the backside! 3. Now you can see a
black coloured round metal spring, take that one off (
red arrow):
4. Now you can take out the
On-Off-Switch / Shutter-Release-Button:
Take off the "snap-ring"! You can see, it this switch/button is pretty dirty ... and I won't clean it, I slaughtered this damaged *ist-DS for its solenoids and the focusing-screen only! (The use of the solenoids is well known by now in this forum, the f.screen is the better one for the K10D/K20D) 5. Now you have 2 parts:
a) The
springloaded Shutter-Release-Button:
I only realized how dirty it was when I checked the photos!
and
b) The
ON/OFF-Switch
All parts disassembled:
Clean well, apply some grease to this tiny ball and were it runs. I have used some thick bearing-grease which does not affect rubber).
Or "valve-lubricant" such as "Dow-Corning Molykote 111" or a good silicon-grease.
Assemble and hopefully all is well now!
