DIY: Flash grid
Posted By: skinja, 03-13-2009, 09:41 PM
I built this flash grid with straws, hot glue, a cereal box, Gaffers tape, elastic strap and velcro. This is pretty easy to build but it takes a little time.
You can build the same thing out of a corrugated box a little glue and a rubber band.
for more info see the strobist web site, I don't remember the link to site that led me down my path.
This is was designed for and mounted to a viv 285, no velcro applied to the flash. It fits the 360 good and should work just fine on any flash head smaller then the 285.
__________________
03-16-2009, 05:51 PM   #2
Thanks for the submission. I've now approved this article!
04-24-2009, 07:17 AM   #3
Falld5's Avatar
What results is this grid supposed to have on photos? Never saw anything like this before. Thanks.
04-24-2009, 07:55 AM   #4
Venturi's Avatar
Grids focus the beam coming from the flash into a tighter pattern. The density and depth of the honeycomb control how tight the "spot" becomes.
Say your flash normally projected a spread/pattern of 8ft on a wall when fired from 10ft away. With a grid attached, depending on the above, it might tighten that up to a shaft of light 2ft wide from the same distance. (example for sake of discussion only!)
They're great for isolating your subject or for adding hair/kicker light to add some depth to the shot.
04-24-2009, 12:42 PM   #5
Falld5's Avatar
I'll be. I like this forum. I'm learning something new everyday. Thanks!
08-03-2009, 10:50 PM   #6
skinja's Avatar
Definitely a very helpful group.
08-03-2009, 10:58 PM   #7
pete_pf's Avatar
very nice grid spot. i'm in the middle of making one myself where'd you get the straws? :P
08-06-2009, 08:16 PM   #8
skinja's Avatar
QuoteOriginally posted by zenimagery Quote
Thanks,
Restaurant supply store 500 for 4.00$. Post some pictures when you get done.
box, diy, do it yourself, flash, glue, grid, site, velcro, yourself
DIY PTTL Macro Flash wildlifephotog Photographic Technique 3 10-12-2009 01:36 PM
My DIY flash Bouncer tcdk Flashes, Lighting, and Studio 19 02-16-2009 03:49 PM
Flash grid skinja Flashes, Lighting, and Studio 1 02-02-2009 11:59 PM
My DIY Macro Flash Diffuser aegisphan Flashes, Lighting, and Studio 2 04-19-2008 09:03 AM
DIY slave flash problem gamgee Flashes, Lighting, and Studio 4 04-03-2008 09:56 AM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
