07-24-2010, 11:47 AM   #1
pentax optiow80 problem
When i switch on my optio w80 the screen comes up for about 3 secs then goes black,i cannot see what i am going to photograph,although when i press the button i get a picture ,but its no good as i cannot see what i'm taking...please any ideas what is wrong...thankyou .
07-25-2010, 05:46 AM   #2
Click on the DISP button once to activate live view through the screen.
07-25-2010, 02:40 PM   #3
..Thanks Adam for reply,i do not have a disp button.
07-25-2010, 04:42 PM   #4
After you turn the camera on press the menu button. Then scroll to the Rec. Mode menu (red camera). Scroll down through this menu to "Memory". In the memory menu scroll down and you will see "DISPLAY" with a box next to it. If the box is checked, uncheck it.
The camera thinks you want it to remember your display preference, which was set to off. Now it should start with the default live view each time it is turned on.
07-26-2010, 12:34 AM   #5
QuoteOriginally posted by lowspark86 Quote
YOU HAVE MADE MY DAY ,thankyou i am just about to go on holiday with out my camera it is now working perfect.Thankyou very much lowspark
07-26-2010, 10:43 AM   #6
QuoteOriginally posted by salmon12 Quote
No problem, glad you will be able to enjoy it.
A couple more things that may help you:
The display view changes when you press the center OK button. From what I remember there are 4-5 views. Basically it changes what information is displayed along the edges of the lcd. The last setting is "off" which turns the live view off. Pressing the OK button will cycle through these different views.
If you find you prefer one of the other views better than the default (say you choose one that is less cluttered or you like the one that displays the histogram) then you can go back to the "Memory" and "DISPLAY" menu and re-check the box to remember your display preference. It remembers what view/display option was each time the camera is turned off. And again, you can cycle through views and turn the display on/off by using the OK button.
07-26-2010, 03:49 PM   #7
..Thats something else iv'e learnt about the Optio,thankyou.
digital camera, pentax cameras, point and shoot
problem with pentax pz-1 / z1 molotvo Pentax Film SLR Discussion 6 12-20-2009 11:01 PM
Old Pentax problem groucho49 Pentax Compact Cameras 4 01-19-2009 02:48 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Pentax 16-50 mm da* problem h0rnd0g Pentax SLR Lens Discussion 5 09-11-2008 08:06 AM
Problem, pentax 1.4x-s roy Pentax SLR Lens Discussion 11 03-03-2007 07:20 PM
All times are GMT -7. The time now is 11:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
