02-07-2011, 06:59 PM   #1
Optio WG-1 Looks Good, But
will the 14mp sensor be back lit and give lower noise photos than the 12 mp WP90 sensor .... that is the question !
wll
03-09-2011, 03:46 PM   #2
I tested a pre-release WG-1 yesterday, and while it wasn't a technical side by side comparison, the files looked quite a bit better than the W90, which I wasn't terribly impressed by.
You can watch the video here if you are interested:
04-09-2011, 02:40 PM   #3
just got mine today
04-10-2011, 01:16 PM   #4
today I am already unsatisified with it
the IQ is bad lens flare an issue
battery door seems loose - could it prevent water from flowing inside ? woudn't try it... no...
dont know what to do
maybe I will return it
04-10-2011, 02:29 PM   #5
this small crap camera goes back to Pentax
how could it take pictures under water in case
if it coudn't do that above water -wow what a crap!
05-06-2011, 04:31 PM   #6
QuoteOriginally posted by dreamfoto Quote
I'd be interested in some photos showing the bad IQ and lens flare issues.
I found that if I keep the ISO <= 200, the IQ will be OK. This thing is designed as a point and shoot for the outdoor enthusiast. Logically all the default settings are suitable for an inexperienced user. I turned off some of the auto settings, customized the green button and don't expect it to produce the exact same results that a DSLR can produce. This is a camera to have "outside" your floatbag on a kayak trip, to "use" during a downpour while hiking on or to take snorkeling.
Yes, it can. The reason why it "seems" loose is because the outer parts of the doors actually are a bit loose. Both doors (the one over USB and HDMI ports as well) are made of multiple parts, that are connected loosely on purpose. There is the part on the hinge with the gasket, that actually seals the compartment. Then there is a sliding part that keeps the door closed and finally a little lock on that slide, that prevents accidental sliding (open). These are plastic parts, not precision machined stainless steel. Naturally there are small gaps that allow you to wiggle that outer door part around a bit. The way it is assembled avoids that this wiggling on the outer part moves the actual door and causes wear on the rubber gasket.
JC
digital camera, optio wg-1, pentax cameras, point and shoot, sensor
Pentax Optio W 90- good ? lesmore49 Pentax Compact Cameras 23 03-10-2011 12:43 PM
Optio RZ10 review: "Surprisingly good" gazonk Pentax Compact Cameras 2 01-24-2011 11:20 AM
Pentax announces the infinitely customizable optio rs1000 and optio rz10 with 10x zoo Adam Homepage & Official Pentax News 0 09-08-2010 09:10 PM
PENTAX UNVEILS THREE NEW DIGITAL CAMERAS: Optio I-10, Optio H90, Optio E90 Adam Homepage & Official Pentax News 11 01-26-2010 07:21 PM
Help getting good pics with optio s30 Kirst Pentax Compact Cameras 3 07-18-2007 12:08 PM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, part of our network of photo forums!
