It works! Borrowed an Optio S60. Little bigger than the "Altoids" Pentax. It has the same 3X zoom lens. First I tried setting camera to super macro. Wouldn't focus. Then tried on normal macro. It focuses. You have to zoom the lens up to middle or little greater range to stop vignetting. It was hard to hand hold the DS and use the other hand to hold the S60 up to the rubber eyecup while taking the shot. It can be done. It would be easy to make an aluminium bracket to hold the camera to the DS. Only problem is the fact that the optio screen doesn't "tilt" up like a Zigview. May try a mirror to fix that. Clarence, try it with your camera.
thanks
barondla
