Originally posted by budzy1911 This really makes me think twice about ever buying another camera from them again.
Ok, when I think of murder/crime trials, all I can think about is the term "Reasonable" as in "Reasonable Doubt" in convictions. Maybe "Reasonable" in the context of one's peers. Rational and reasonable seem to go hand in hand.
Exhibit A - My Pentax Optio W80. It has been EVERYWHERE and been through tough times. It has never failed me - as all the previous WR Optios I have owned.
Exhibit B - The back side of the door that covers both the battery and SD card. Notice the little tab that needs to be moved, so that the door can be slid to open. Notice there are no extra safety catches or latches than can prevent the movement of the little tab.
Exhibit C - The tiny little raised edge is all that prevents water from going into the innards of the Optio. The Water Seal, sits against the smooth bottom of the Optio, when the battery/SD door is closed. There is no reasonable assumption or secondary backup that assures that the seal will prevent water egress or failure. A casual observation will reveal that any small particle will compromise the water integrity of the Optio if it lodges against the seal. Before anyone takes an Optio WR into water, an examination of that seal is second nature.
Exhibit D - My niece in the pool under reasonable water use. Yes, waterproof, but with careful understanding of the reasonable parameters of the claim of waterproofness.
When I buy things, I look them over carefully. I examine the manufacturers claims. I make an assement of it based on real world conditions.
Throwing an Optio - ( not including the WG1 and WG2 as they have more robust catches/latches ) in your swim trunks and playing in the water, is asking for the Optio to fail it's waterproofness, as the little tab will definitely move around, as will the door to the Battery/SD slot.
