I ended up using FotoSketcher instead of Pixo. The Pixo program has so many nice plugins, but, it kept crashing with my new operating system
I liked Pixo because you could edit just one area of an image, if you wished, or the whole photo.
Anyway FotoSketcher as the name suggests is a nice little free program that is dedicated to adding artistic touches to digital images. There is a coffee cup icon on the task bar if you wish to donate.
I don't remember where I learned about it, but, tried it and kept it for the great effects to use someday. I did find a couple of threads about it here on the forum, so it has been around a while.
It is a slider run system and is set up with before and after windows. There is also a small cropped window to view changes before you commit to running the program. After you hit the "draw" button, the work is redrawn for you in the after window. It edits up to a medium/large sized jpeg rather quickly. There is a manual brush, but, had too much fun watching the magic happen to go there yet.
Okay, for this image I chose the Oil Paint option. There are six sliders to change things like strength of effect or brush stroke, saturation, detail, texture, brightness. You can add a frame, soften the edges or add text all at the same time. I don't believe I cropped this one, but had previously cleaned up some of the background. I did lighten a bit and desaturated a bit I think.
Anton, thanks for the Photoscape info! I've already downloaded it and when I get a chance will give it a good workout.
