07-19-2012, 07:34 PM   #1
WG 1 mini sd card max
I have looked everywhere I can think of in the manual to find out what the maximum GB that I can use for the mini SD card. Can't find it. So I went ahead and bought a 4 gig card and now it will not format. Can you give me some direction in this? Thanks
07-20-2012, 03:36 PM   #2
ramseybuckeye's Avatar
QuoteOriginally posted by drhugh Quote
Doesn't it take a regular DSHC card, that's what is shown in the manual? Mini cards come in a regular card size adapter, but I don't know if you can format in that adapter or just read. I would try a regular size SD. I don't have the camera but I searched the manual and found no capacity.
07-25-2012, 07:53 AM   #3
CWuestefeld's Avatar
It's not a mini, it's a standard size SD card. It takes SD or SDHC; I don't think it takes SDXC. I use a 16GB SDHC card in mine; I think the SDHC spec allows for up to 32GB.
07-25-2012, 07:58 PM   #4
wanderography's Avatar
I have the wg-1 gps and when I used it for the one time I did it was with a sandisk extreme 16gb, worked flawlessly...
EDIT: a side note, a mini sd card with an sd card adapter works just fine too in it... formated and everything... you might have a faulty camera...
card, digital camera, mini, mini sd card, pentax cameras, point and shoot, sd
Mini HDMI port to mini display on macbook Rnovo Pentax K-5 & K-5 II 6 05-17-2012 11:02 AM
Max card size for DS? PeterAM Pentax DSLR Discussion 2 02-26-2012 03:04 PM
Best type of SD card to use - regular, mini, micro? Oro Pentax Camera and Field Accessories 4 08-13-2010 06:01 AM
Max size for an SD card in K10d russblack Pentax DSLR Discussion 1 03-11-2008 07:47 PM
Max size sd card for k100d/k10d ? shane Pentax DSLR Discussion 17 09-18-2007 01:12 AM
All times are GMT -7. The time now is 03:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
