01-04-2007, 06:48 AM   #1
Optio 33 LF wont switch on??
I have unplugged my camera from the computer without disconnecting it first. Now it wont switch on. What can I do?
01-04-2007, 07:53 AM   #2
QuoteOriginally posted by bsmith Quote
Not quit sure what you mean by this. Do you mean you disconnected it from the computer USB cable before you turned the camera power off?
Did you have it plugged into the wall for power to run it without the battery and you disconnected from the computer USB cable?
Electronics are sensitive and I was having a problem with my cat walking by my computer and causing it to reboot. I did some serious grounding of the computer casing and have no more problems. You may have introduced a voltage spike to the camera when you did the disconnect, either from static electricity or from the USB connection, as it is a power source too.
Remove you battery, recharge it as normal, reinsert battery and try a different memory card than the one that was in there too. Don't know if you camera will not turn on if the memory card is not in the slot but if so it may also not respond if the memory card is fried to the point of not being recognizable. If this doesn't work, take the camera to the dealer and get their input or replacement.
Good luck.
01-04-2007, 06:15 PM   #3
-=JoN=-'s Avatar
could be just dead batteries..
digital camera, pentax cameras, point and shoot, switch
ZX-5n wont soot? Clinton Pentax Film SLR Discussion 6 06-04-2011 06:06 PM
K-7 wont update MrHowell Pentax DSLR Discussion 3 01-17-2011 02:06 PM
Optio E85 wont turn on figgy67 Pentax Compact Cameras 2 11-27-2010 04:11 PM
Pentax to announce Optio H90 & Optio I-10 cameras dopeytree Pentax News and Rumors 92 01-27-2010 09:02 AM
PENTAX UNVEILS THREE NEW DIGITAL CAMERAS: Optio I-10, Optio H90, Optio E90 Adam Homepage & Official Pentax News 11 01-26-2010 07:21 PM
All times are GMT -7. The time now is 06:29 AM. | See also: NikonForums.com, part of our network of photo forums!
