08-20-2013, 09:21 PM   #16
i_trax's Avatar
QuoteOriginally posted by Spodeworld Quote
Where did you get that 'retro hotshoe'!
I just ordered an MX-1 and like the way you set it up
it came with my Praktica SLR purchased years ago , they are popping up from time to time on eBay
08-20-2013, 11:01 PM   #17
i_trax's Avatar
QuoteOriginally posted by klh Quote
Also, which case is that one? Does it fit as well as it looks?
yes, absolutely love it!
Genuine Real Leather Full Camera Case Camera BAG Cover FOR Pentax MX 1 MX1 Brown | eBay
and a strap:
http://www.ebay.com/itm/Hnadmade-Genuine-real-leather-camera-strap-neck-stra...item3cc6a0a7e9
08-21-2013, 06:24 AM   #18
Spodeworld's Avatar
Do you know what you would search for on eBay for that?
Thanks
QuoteOriginally posted by i_trax Quote
08-21-2013, 07:11 AM   #19
Such a good looking set up - the mount is technically a cold shoe though, right? No electricity or triggering going through it, yeah?
12-07-2013, 05:38 AM   #20
QuoteOriginally posted by MX1_fanboy Quote
Not sure I'm getting where you're coming from exactly, but you shouldn't need to use a remote trigger - just set your external flashgun to slave and use the MX1's built in to trigger it.
Works perfectly for me with a Yongnuo 568.
Getting the exposure right is tricky but the guy's tip in the video helps (setting your aperture to wide open in manual, auto-calculate the exposure with the green button, and then narrow the aperture to f8 while maintaining the shutter speed).
I can't get it to sync with my Y 560-III
Tried everything I know. You have it working, so I've missed something - care to share please
12-07-2013, 01:42 PM   #21
BTW: I have no problems using the Yongnuo 560-III with the Pentax Q (or K-7 and K-01) Just seems not to work (sync) with the MX-1 (for me)
12-08-2013, 12:48 AM   #22
Wow, not a soul interested in this cam anymore huh? Oh well... And they said the K-01 was a failure
12-08-2013, 09:15 PM   #23
ka-bump
12-09-2013, 12:24 AM   #24
adwb's Avatar
Set the flash on s2 mode it should see the cameras flash preflash and go off at the correct time to add to the overall flash . S1 will also apear to work but the timing will be wrong.
12-09-2013, 12:46 AM   #25
Yeh, already tried that. Doesn't work.
12-09-2013, 03:44 PM   #26
adwb's Avatar
Does the mx do preflash? If so then set the Mx to red eye that should at least trigger the yn even if it then flashes at the wrong time , if not then it's faulty, I would think,
12-09-2013, 04:16 PM   #27
Fault? - how could there be, the built in flash works fine and syncs with the shutter.
You have either Flash-on, Flash-on + Red eye, Slow-speed sync, Slow-speed sync + Red-eye, Trailing-curtain sync.
I have tried them all.
The Yongnuo works fine with the Q, the K-01 and the K-7, so the Yongnuo speedlight works fine too. There seems to be some incompatibility between the MX-1 and Yongnuo
12-10-2013, 01:24 AM   #28
adwb's Avatar
Very odd makes no sense at all, no ideas in that case it's as if the flash output on the mx is not being "seen" by the optical sensor on the flash for some reason , which since it sees the other models is very odd.
12-10-2013, 01:50 AM   #29
It sees it, and it flashes - just not in perfect sync to make any difference to the shot. Only the built-in flash illuminates the subject.
Easy to test as well, take a photo of the flash unit.
Do this with the Q, K-01 and K-7 and you get a photo of the Yongnuo lit, do it with the MX-1 and you get a shot of the Yongnuo dark, but it did flash - easy to see with you eyes at the time.
Example: Pentax Q triggering the Yonguo
12-10-2013, 02:14 AM   #30
adwb's Avatar
is the same in both S1 and S2 modes?
digital camera, flash, pentax cameras, point and shoot, video
The Camera Store and MX1 john5100 Pentax Compact Cameras 14 02-20-2013 01:55 PM
K5 with A-lens and wireless flash problem glasbak Pentax K-5 8 01-13-2012 06:16 AM
K-x popup flash AND wireless P-TTL with AF-360 FGZ? runswithsizzers Flashes, Lighting, and Studio 5 07-29-2011 11:21 PM
m42 and wireless flash Urmas R. Flashes, Lighting, and Studio 2 03-14-2009 03:48 PM
K10D and wireless flash photodad Pentax DSLR Discussion 9 02-10-2007 11:10 PM
All times are GMT -7. The time now is 01:53 PM. | See also: NikonForums.com, part of our network of photo forums!
