Originally posted by Adam You can adjust the brightness and hue via the menu. The final product is always best viewed on a computer, though, regardless of the LCD. And BTW, the K-30 has the same screen as the K-r hardware-wise.
Okay so K30 has new upgradable feature that I need to downgrade
Quote: By "see" do you mean that the camera isn't recognizing the focal length and giving you the F-- error? If so, try cleaning the lens contacts.
My bad description. I meant the exif data. The Kr records correct data and I can see lens information in the management tool (It's digikam / Linux). This is not true for K30 when I see "lens: unavailable"
I guess this is probaly due to . the .DNG format.
Btw, I don't see a way to select ".PEF" format. There is only .DNG for K30 while I can use .PEF or .DNG on Kr
