02-08-2014, 06:05 PM   #31
jtkratzer's Avatar
I just got this camera this week and I don't see any issue with speed shooting RAW+, keeps firing away. It does make you wait to access menus or change settings, but I have yet to kill the buffer when shooting in single shot drive.
I was hoping to see that Pentax was going to be doing firmware updates for minor improvements and that's why I stumbled into this thread.
02-23-2014, 11:37 AM   #32
cali92rs's Avatar
Not allowing the camera to do anything with the lens cap on is the first thing I would change. ..
02-23-2014, 01:33 PM - 3 Likes   #33
QuoteOriginally posted by cali92rs Quote
Well you can preview and delete images, also you can make menu changes with the lens cap still on.
Just press and hold the Preview button on the camera to start it up without the lens extending.
02-23-2014, 02:21 PM - 1 Like   #34
cali92rs's Avatar
QuoteOriginally posted by Steve.Ledger Quote
Thanks for that tip
I guess I should read the manual before I complain...then again what would the internet be with complaints
03-28-2015, 07:52 AM   #35
rrodgers's Avatar
Firmware Release for the MX-1
QuoteOriginally posted by Tanzer Quote
In the "old" K-5 method, if you hold down the menu button when you power it up, it tells you the firmware release. But that doesn't work on the MX-1 either. So I don't believe it would give you an option to import a bin file in the SD card's root directory, either.
So I don't believe the MX-1 can be field upgraded.
I have tried the "old" K-5 method of checking the firmware release number, i.e. hold the menu button while powering up, and my MX-1 certainly displays, "VER 1.00". This suggests to me that Pentax thought there might be the possibility of other firmware versions
03-29-2015, 09:09 AM   #36
Spodeworld's Avatar
Too bad they didn't think it worthwhile to do one. Faster RAW writes would be a huge improvement
QuoteOriginally posted by rrodgers Quote
03-29-2015, 01:11 PM   #37
The Olympus version of the MX-1 had a firmware update..
But this has all been hashed out before..
I don't find the RAW writes any slower than the Q.
03-30-2015, 08:33 AM   #38
I stand corrected, not sure why I didn't see this earlier -- maybe because one has to hold them both down for a little bit longer than on the K-5. Since no one called me out on this earlier, maybe nobody else who tried this waited long enough either.
Thanks for coming back to the thread with the corrected information. I would edit my earlier incorrect post, but it looks like I can no longer edit that (maybe it is too old).
03-30-2015, 08:00 PM   #39
Probably a hardware limit. With a fast class 10 SD card a raw file writes in 2-3 seconds. Not too bad for 20 MB. And switch off raw+jpeg, the raw includes a perfect full jpeg already. IPads can read/import the raw and save as jpeg of about 3 MB.
03-30-2015, 08:17 PM   #40
Thanks, but you're preaching to the choir here
10-05-2016, 12:19 AM   #41
QuoteOriginally posted by RiderX Quote
After more than 3 years of heavy use of my MX-1, I still think that the time to write RAW files is a little slow, even with the latest fastest cards. Probably due to a hardware limit as you say...
03-26-2017, 02:26 PM   #42
GuitarGuru76's Avatar
My MX-1 shows Firmware Version V666-53, Holding Menu button down when powering up. Anyone else with this firmware version?
03-26-2017, 02:49 PM   #43
I no longer have my MX-1, but Ricoh never released public FW updates for the MX-1.
04-06-2017, 07:41 AM   #44
QuoteOriginally posted by GuitarGuru76 Quote
Mine shows VER 1.00
04-06-2017, 08:15 AM   #45
QuoteOriginally posted by gaweidert Quote
Mine shows VER 1.00
Thanks for the reply. I guess my camera must be a pre production model. Seems to be in some kind of development​
mode.
button, camera, digital camera, firmware, lens, menu, mx-1, mx-1 new firmware, pentax cameras, point and shoot, post, preview, ricoh, version
New Firmware Update V1.31 FrankC Pentax Medium Format 9 10-25-2013 10:59 AM
Q new firmware update 1.13 now available grahame Pentax Q 43 07-13-2013 05:27 PM
K-r firmware update 1.13 alexmkd Pentax K-r 22 07-06-2013 05:55 AM
K5 Firmware Update 1.14 WightWalker Pentax K-5 5 02-25-2013 12:49 AM
New FIrmware Update v.1.12 geru2000 Pentax K-r 53 06-07-2012 11:30 AM
All times are GMT -7. The time now is 09:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
