04-24-2008, 08:00 AM   #1
SD card format problem?
Hi - I'm using a Pentax Optio W20 and a 2 GB SD card that I've been using for years. I formatted the SD card in my PC in order to upgrade a laptop, and now the SD card isn't working.
I tried using the format utility here: Downloads - SD Card Association
But it still doesn't work in the camera - the camera still only sees the internal memory.
Another weird thing is the format utility report. It is reporting only 980 MB available, which is what my PC says when I look at the properties there.
In the worst case scenario where I have to replace it, what is the maximum size SD card this will hold?
Thanks in advance!
04-24-2008, 08:25 AM   #2
Ahab's Avatar
I believe the owners manual tells you to always format the card in the camera. You may be plain out of luck. I've always just used the 2gb cards.
camera, card, digital camera, format, pc, pentax cameras, point and shoot, sd, sd card format, utility
*ist DS "memory card error" - card won't format WMBP Pentax DSLR Discussion 6 04-05-2016 04:39 PM
How to format card for firmware update Corvairfan Pentax DSLR Discussion 7 11-06-2010 05:31 PM
Forgot to format new card - can I save my pictures? T K Hull Pentax DSLR Discussion 7 06-13-2010 09:00 PM
SD Card Problem dogbear1980 Pentax DSLR Discussion 5 01-09-2010 05:29 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
All times are GMT -7. The time now is 09:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
