05-12-2014, 10:18 PM   #1
Polarizing filter adapters for the Ricoh WG4?
Hello,
Would anyone know if the macro stand O-MS2 is threaded like the older macro stand O-MS1? Thread diameter is the same, 46mm? Same question for the lens adapter O-LA135. Thread diameter is still 46mm? The mounting of these adapters is sturdy enough so that they can be permanent, safe, on camera?
Thank you
05-12-2014, 11:06 PM   #2
I just looked at the macro stand and yes, it's threaded. I didn't have a ruler handy but 46mm looked about right
06-20-2014, 06:19 AM   #3
ExpatKiwi's Avatar
Did the 48mm filter fit the thread? The one issue I have with the WG3 is sunlight hitting the front lens shield causing purple haze in the image center. The camera almost needs a lens hood.
06-27-2014, 01:18 PM   #4
ExpatKiwi's Avatar
I originally purchased the WG-3 to take with me kayaking and hiking and not have to worry about the camera getting wet. The one issue I have noted is the lens flare and purple hazing when sunlight hits the outer lens shield at an angle. I also thought it would be nice to be able to use a CPL at times on those really bright sunny days on the water. Using the supplied macro stand O-MS2 I attached a 46mm to 52mm step up adapter ring so I could use my existing 52mm CPL filters and rubber hood and minimize the risk of vignetting at the wide angle 1.0x zoom. However, I still noted vignetting when wide, zooming in a fraction clears it. I could also use a petal hood.
I've attached some pictures below of the attached adapter and an HDR picture directly from the WG-3 with the hood on so you can see the vignetting at top right. One other thing is that when using the adapter it obscures the AF assist light and flash. I only plan to use this during bright daylight so don't see this as an issue.
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX WG-3  Photo
10-24-2014, 12:58 AM   #5
The O-LA135 adapter has a diameter of 37mm not 46mm like the macro stand !!!
It is more sturdy than macro stand. Besides, with the macro stand I lost a polarizing filter in a small fish pond. Then it was stolen in a trip through Italy with my backpack with some camera equipment .
So I bought the O-LA135 adapter.
The O-LA135 is even so robust, without a tool I can not get out of the camera. Even with a tool is difficult to remove it . But I do not mind if it stays on the WG4.
I used a 49mm polarizing filter with step up ring. Indeed in this case there is an obscuring the flash and AF assist. That's why I ordered a 37mm filter. Otherwise the 49mm adapter ring and filter it seems to me that the device is already bulky.
WG4 has also chromatic aberration. But I think it's a general problem for the compact point and shoot cameras.
01-02-2015, 02:46 AM   #6
Okay, I just bought a ricoh wg4 and plan to get a polarizing filter for when I do mountain hiking shots. Can some one please tell me (specifically) what I need to get. Its clear from reading the comments up top I will need an adapter to widen my mount to use a polarizing filter and then the filter itself. Also can I get filter recomendations. I would like to not spend more than $50.00 but am willing to spend up to $75.00. I want one that will do its job properly.
46mm, adapters, diameter, digital camera, filter adapters, macro, pentax cameras, point and shoot, thread
ND or Polarizing filter for my two lens? Newtophotos Pentax SLR Lens Discussion 7 08-31-2013 04:46 PM
Polarizing Filter for M42? Tedd05 Troubleshooting and Beginner Help 2 06-23-2013 08:25 AM
Hawaii trip .... polarizing filter for 18-135WR ? Brownie4u Pentax SLR Lens Discussion 18 05-17-2013 03:03 AM
Lens polarizing Filter for 15mm limited and 18-135 Skipper74 Pentax K-5 3 01-05-2013 10:13 PM
Polarizing Filter Recommendation for 45mm lens. Swift1 Pentax Medium Format 9 11-30-2009 03:21 PM
All times are GMT -7. The time now is 12:44 PM. | See also: NikonForums.com, part of our network of photo forums!
