07-29-2014, 08:25 PM   #1
Do you see MX-1 UV filter in the market?
Do you see any MX-1 UV filter available in the market?
10-07-2014, 11:28 PM   #2
rburgoss's Avatar
Since the MX-1 lacks a threaded lens barrel, you cannot attach any filters to it. There is only one filter that can be used and its available, which is a circular polarizer that attaches magnetically to a supplied metal ring the you permanently stick to the lens barrel edge, but the filter has to be removed in order to turn off the camera allowing lens to fully contract. If interested, look for the MAG FILTER 42mm at B&H or elsewhere. This is the size that fits the MX-1.
If you are looking for lens protection, you will have to settle like the rest of us with this nice beasty... by being more careful. Optically, any filter (even best quality ones) will always have a negative impact in image quality.
But there is one real accessory I would like to find, which is a matching lens angles (tulip type) lens hood. That will be a magnificent image quality improve. I guess its time to pull out the tools and stuff.... one custom shade is on the go!
10-08-2014, 03:48 AM   #3
There is this critter on the market. It is a tube that fits on the lens base and you allows you to use 58mm filters.
Amazon.com : Metal Lens / Filter Adapter Tube For Pentax MX1 58mm MX-1 : Camera Lens Adapters : Camera & Photo
10-08-2014, 06:19 AM   #4
rburgoss's Avatar
QuoteOriginally posted by gaweidert Quote
You are right. I forgot about this interesting gadget. Personally never seen one or played with. Forgetting the loss of compact-ability of the camera ( no size reduction when turning off), I would pay special attention to two other issues with this gadget. The method of attachment to camera body ( possible wear and tear around the outer lens barrel where it attached to body, and possible vignetting at the widest setting.
But yes, this thingie will allow the use of any 58mm threaded filter.
digital camera, filter, mx-1, mx-1 uv filter, pentax cameras, point and shoot, uv
Landscape Do you see what I see??? nms_photog Photo Critique 7 02-02-2014 05:59 PM
Macro do you see the ant ? jcserlet Photo Critique 2 12-28-2013 11:00 PM
shooting Tri-x, do you need a UV filter? wcurtiss Film Processing, Scanning, and Darkroom 4 11-17-2010 07:03 PM
n00b question: Do you use have a UV filter (at minimum) on all your lenses? innershell Photographic Technique 35 08-14-2008 03:37 AM
Do you UV filter? imadethis Pentax SLR Lens Discussion 12 10-06-2007 12:53 PM
All times are GMT -7. The time now is 12:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
