09-10-2015, 02:43 PM   #1
Optio M20 uploading help
Hi, I have my Optio M20 cable attached to my laptop. My problem is I'm unable to upload photos to my computer. Are you able to help?
09-10-2015, 02:59 PM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Does the Optio show up as a disk drive in your computer? And which computer, PC or Mac?
09-10-2015, 03:17 PM   #3
QuoteOriginally posted by photolady95 Quote
Hi photolady. No, my Pentax Optio M20 does Not show up on my disk drive of my Toshiba Satellite laptop, Windows 7 also.
09-10-2015, 03:27 PM   #4
After plug the cable in, did you turn the camera on?
Your Optio should show up as a separate removable hard drive or disk.
09-10-2015, 03:32 PM   #5
Photolady95, my Optio does Not show up at all. Neither as a removable hard drive or disk.
09-10-2015, 04:09 PM   #6
Did you try restarting the laptop? Does your laptop not have a card reader?
09-10-2015, 04:11 PM   #7
QuoteOriginally posted by kbrandt4261 Quote
It only stays on for a short while. Also, there used to be a green light that would come on the left above the lens.
09-10-2015, 04:15 PM   #8
What stays on for a short while, the camera or the computer?
Most of use a card reader for removing photos from our cameras. Do you have one of those, or does this camera not have a SD card and only internal memory?
09-10-2015, 04:49 PM   #9
The camera stays on for a short time. The card reader is in the computer and I have a memory card in the camera
---------- Post added 09-10-15 at 04:50 PM ----------
I'm not sure what a SD reader is. Can you be more specific, please
09-10-2015, 05:02 PM   #10
Take the SD card out of the camera and insert it in the card reader.
As for my reference to SD I meant to add card also.
09-10-2015, 05:21 PM   #11
I do Not have a card reader on my Toshiba Satellite laptop. Sorry, I thought I did.
---------- Post added 09-10-15 at 05:37 PM ----------
My camera is now showing up on my computer, but I still can not upload pictures to it.
09-10-2015, 06:02 PM   #12
Do you see a drive there in the list of drives on you computer? Click the down arrow beside that drive/disk. Do you see a folder after doing that?
09-10-2015, 06:06 PM   #13
No, I do not see it in my list of drives. I've looked at it several times and I see nothing.
09-10-2015, 06:08 PM   #14
Then it's not actually being seen by the computer. Simplest solution would be to buy a USB card reader. Some are fairly cheap at about $10.
09-10-2015, 06:11 PM   #15
I bought this one from Amazon and love it.
http://www.amazon.com/IOGEAR-Pocket-Memory-Reader-GFR209A/dp/B004QHPYT0/ref=...=p_89%3AIogear
camera, card, card reader, digital camera, m20, optio, optio m20, pentax cameras, pentax help, photography, point and shoot, reader, troubleshooting
optio m20 problema obbiettivo gianmario1976 Troubleshooting and Beginner Help 2 06-30-2011 10:34 PM
Problems uploading photos from Optio M20 sidest Troubleshooting and Beginner Help 2 05-25-2011 04:19 AM
Optio M20 light sensor issue michla Troubleshooting and Beginner Help 2 01-12-2011 11:30 PM
Problem with Optio M20 cjiveson Pentax Compact Cameras 3 08-26-2008 05:31 PM
Optio m20...Feeling out of Place here flpoodle Pentax Compact Cameras 5 04-25-2007 06:32 AM
All times are GMT -7. The time now is 07:03 PM. | See also: NikonForums.com, part of our network of photo forums!
