12-15-2015, 12:20 PM   #1
Spodeworld's Avatar
MX-1 finally crapped out on me
Well, it was a decent camera while it lasted. But, about 1 1/2 years ago, the lens stopped retracting. Not to fear (too much) though as I had the aftermarket filter extension on the barrel, so my lens was not exposed. It may not have closed, but between the extension on the barrel and the UV filter, I was able to deal with a permanently extended lens. However, recently, it started complaining that the lens cap was on and turns itself off. Wondering if anyone else experienced this and if they found a fix for it.
Too bad, but maybe not too bad after all. The IQ was very good at low ISOs, and it was a nice looking, sturdy camera, but the AF was irritatingly slow and the shot-to-shot time in RAW was painful.
12-15-2015, 02:51 PM   #2
Given the price the MX-1 was originally sold for, I would have expected it to last longer...especially considering its tough retro appearance. How heavily did you use the camera?
12-15-2015, 03:09 PM   #3
Spodeworld's Avatar
I did use it fairly heavily and regularly had it with more...perhaps more than any other camera. A year ago and then some the retracting mechanism stopped working properly, and now the additional problem happened making it unusable....unless I can figure something out. I would have expected better durability, but maybe I just got a lemon.
12-15-2015, 04:33 PM   #4
severalsnakes's Avatar
I wonder if there's a sort of "hard reset" you could do? I have a Sony Cybershot (not the same thing, I know) and it stopped retracting the lens after less than a year. A Sony representative on their site's online chat instructed me on some secret combination of buttons to press/hold/take the battery out/etc that did some readjustment to godknowswhat and it's been working fine ever since...
Edit: Although I don't use it heavily, I have had the MX-1 for 2 years in January and it is still going strong! No issues at all. (Knock on wood.)
12-15-2015, 04:38 PM   #5
Sounds like something got inside the lens retracting mechanism, sand or grit perhaps which finally work it's way right inside.
The MX-1 needs to function long enough for natural brassing to occur. Brassing was a much marketed feature.
12-15-2015, 04:46 PM   #6
Biro's Avatar
QuoteOriginally posted by Spodeworld Quote
I also had the MX-1 and concur with your remarks here. I liked the MX-1 but not enough to the keep it when the Ricoh GR came along. I would suggest taking a look at the GR or the Panasonic LX100 (which I also own) as potential replacements if you could swing such a purchase now.
12-15-2015, 08:26 PM   #7
Spodeworld's Avatar
Ever since the lens stopped retracting I can hear the gears at work whenever I Turn it on or off. I can also see a tiny bit of movement. But, when I put a little pressure on it when I turn it off to try to coax it along, it quickly meets with solid resistance.
QuoteOriginally posted by Steve.Ledger Quote
12-16-2015, 01:16 PM   #8
Spodeworld's Avatar
Started working again....I guess it has a mind of its own. Lens still extended all the time, but at least it turns on now.....
12-16-2015, 03:35 PM   #9
Biro's Avatar
But us it really pocketable with the non-retracted lens?
12-16-2015, 06:50 PM   #10
Spodeworld's Avatar
No, but I've had the aftermarket barrel on it for a while to use filters, even before this problem, so it's always been larger than it would be, even extended. But, even without that, when retracted it's not really pocketable, unless you're talking about a pretty big picket.
barrel, camera, digital camera, extension, filter, lens, pentax cameras, point and shoot
My take on the MX-1 skyoftexas Pentax Compact Cameras 13 04-17-2015 09:33 PM
MX-1 on location Bermuda ExpatKiwi Pentax Compact Cameras 2 07-28-2014 03:17 PM
Mx-1 ovf add-on? wjhawthorne3 Pentax Compact Cameras 6 02-24-2014 01:31 PM
Modern flash on Pentax ME/MX ChrisR Pentax Film SLR Discussion 3 03-17-2013 01:22 PM
On of my kids finally posed for me. dws1117 Post Your Photos! 14 02-02-2009 01:31 AM
All times are GMT -7. The time now is 02:50 AM. | See also: NikonForums.com, part of our network of photo forums!
