Haven't seen an Optio 60 yet. Not sure what settings are on it. Any macro situation has very little depth of field. The more magnification you use the less DOF you get. Your 60 will have much greater DOF than a similar DSLR. On those cameras it is common to stop the lens down to f11, 16 or more. You might be able to use flash to cause lens to stop down more. Also might be able to use higher ISO to do same. Higher ISO isn't usually a P&S strong point. Does your camera have macro only or does it also have S macro?
Can you post a few shots?
thanks
barondla
Check out POINT & SHOOT CONTEST #10 WINNERS IN P&S forum. Enter #11. Any brand camera. Any subject. Enter now.
