Originally posted by pinholecam Not only do you need the K50, you will also need as wide a lens as you can get.
There will be many nice historical buildings where it will be hard to move further back and as such a UWA will be essential.
I'd rather have a K50 and a 8-16 / 10-20/ 10-24mm for some sort and no other lens.
Throw in a small 50mm for any shallow DOF stuff and you are done.
If it was a fixed 28mm, like a Sigma DP1m or the GR, I'd have to bring along a pano mount or DIY a simpler one (since the optical center will be fixed ). Then I can do vertical panos.
It's actually an 18mm on the GR, Pinholecam, that's right in line with the lenses you suggested on the K-50!
