01-27-2009, 05:29 AM   #1
raider's Avatar
PnS camera's focal length do not tally with exif?
When I am using my PnS, I observed that the exif focal length information is always incorrect. Say if I am using a 200mm focal length, it will report something like 6.2mm. How do I rectify this issue?
01-27-2009, 06:24 AM   #2
Lowell Goudge's Avatar
many PnS focal lengths are indicated in 35mm equivelent for the user, but in exif are reported as actual,
01-27-2009, 04:38 PM   #3
raider's Avatar
Thanks Lowell.
But this is a major problem if we try to put a border frame (with exif information) on the picture. The exif's focal length info is just weird.
I am using a fuji s6500fd by the way and in 35mm terms, its focal length is from 28mm to 300mm. Why would the exif report something like 6.2mm?
Is there any software that can translate/convert this 6.2mm to a more meaningful 35mm terms?
Thanks
01-28-2009, 05:41 AM   #4
QuoteOriginally posted by raider Quote
Thanks
Do you really need any software? If 6.2mm from EXIF is the wide end of the lens (28mm equivalent), all you need to do is multiply the focal length by 4.5.
The same as with APS-C sensor, just slightly bigger 'crop factor'
01-28-2009, 06:47 AM   #5
RBellavance's Avatar
Because that is the actual focal length of the lens.
The EXIF should contain a field named "FocalLengthIn35mm", which contains what you want. I don't know if the software you use to make the frame can be customized to use this field instead.
Otherwise, you could use a script (or batch file) using ExifTool to modify the focal length field to what you want.
01-28-2009, 08:26 AM   #6
I use PSP X2 and it shows both real focal length in mm and 35mm equivelent in the EXIF data.
01-28-2009, 04:28 PM   #7
raider's Avatar
I use faststone image viewer and irfanview. Both did not show the correct focal length. The real hassle I face is when I tried to put a border frame (with EXIF info) on the photo.
01-29-2009, 05:35 PM   #8
LaRee's Avatar
Actually I just noticed this same thing looking at my sister's photos and trying to help her out with her new p&s. We we viewing in windows viewer and I thought that was why. I didn't know that irfanView and Faststone presented the same way. I wonder why too.
02-11-2009, 08:40 PM   #9
I just checked a file from our Ricoh GX and in Faststone it didn't have a "35mm equivalent" value. Haven't got it installed here, but wondering if PhotoMe (or similar) that show all EXIF info would show a field with it in.
02-12-2009, 12:57 AM   #10
Jodokast96's Avatar
Actually, I do think it is listed in Irfanview.
digital camera, length, pentax cameras, pns, point and shoot
focal length ewig Troubleshooting and Beginner Help 11 07-23-2010 09:32 PM
focal length on camera using sigma 170-500 and tamron 1.4 af tele-converter jon pafford Pentax SLR Lens Discussion 2 03-01-2010 08:00 PM
Focal Length from EXIF metalfab Pentax SLR Lens Discussion 3 03-27-2008 06:13 AM
Focal Length Jimsi777 Pentax SLR Lens Discussion 2 11-09-2007 06:46 PM
Camera asks for focal length each time? DMH Pentax DSLR Discussion 22 10-05-2007 09:53 AM
All times are GMT -7. The time now is 06:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
