Originally posted by borisagrees What would be the best all round metering to use?
It depends.
It really helps if you understand what each metering mode is and the general idea of how they work. That way, you'll know the limits of each mode and when to use them. Matrix metering mode takes into account the whole frame when metering, which is all fine and dandy, except when you've got scenes of strong contrast, like you have here.
Here's a thought exercise using the first photo. Imagine you had chosen spot metering:
a) you then put the centre of the frame on the sky, and metered from the sky. What would the image be like?
b) you put the centre of the frame on the ground and metered from the ground. What would the image be like?
Think about it
a) The image would be similar to this. The image is exposed for the sky, so the ground looks underexposed:
b) The image would be similar to this one. The image is exposed for the ground, and hence the skies are overexposed and blown out.
What the camera did when you chose matrix metering was chose a sort of average, or a best compromise of these two to give you the photo that you got.
