Originally posted by J.Scott The Olympus 770SW is rated simply the best bad weather and sturdy P&S digi - bar none. But the bad side is that it takes just average pictures and lousy movies at 15 FPS. I am not a diver but the ruggedness does appeal to me.
Okay, I have played with Oly 770SW lately for testing purposes. It's image quality is nothing to write home about, typical noisy compact pictures. Those pictures are mostly for recognising faces and places, not for putting up in the gallery. You can't control aperture or shutter, you either have to set it on automatic or try to figure out which of its 24 (or something) scene modes will have desired combination.
It's not exactly comfortable to hold, the body is all slippery metal and there are no rubber bands or notches to help the grip. Macro focusing is slow and pretty much is constant hit and miss as soon as there are distracting objects in the background.
However, it really is waterproof and shock/drop resistant. I tossed it around the beach and washed it up in the sea, took underwater pics, turned it on and off in the water, shook it to dry etc etc. It just kept working and taking pictures. I left it running on movie mode in the refrigerator and half an hour later it was still faithfully recording without a hitch. I'm not exactly a light guy and it survived me stepping on it. I was sitting in the rain in the harbour and snapped happily while I probably would've been hesitant to do the same with regular cam.
So yea, in that sense it is outdoor camera. You can drop it from the boat and pick up later on and it'll still be working. It's graded for 10m underwater depth and it's probably the limit since while it's seals are rubberised, they don't exactly have industrial strenght look. But still, it seems to survive a lot.
Having noisy camera in situations where you normally wouldn't have any camera at all may offset some of its limitations, depending on your needs.
