03-02-2010, 01:36 AM   #1
Two Problems with Pentax Optio 30
Group,
I have 2 unresolved problems with my Optio 30.
1.The camera will oly work with 1.2 volts NiCd or NiMH batteries and if I attempt to use 1.5 Volts batteries the message Battery Depleted comes and the camera does not boot.
2.I had been using a 64 MB sd card but lately the camaera when turned on gives the Memory Card Error fault.Trying to format results in the same message.The SD card can however be read using a card reader.I am now using the built in memory which enables me to take 7 pics in Superio mode.
Please help!!
Santhosh
Malaysia
04-08-2010, 08:15 PM   #2
Pentaxie's Avatar
IMO,
- Read the user manual and stick with the instruction. Using different battery voltage will not get you anywhere as the instruction manual says otherwise.
- use a different memory card and test it. If same problem persist, then something is wrong with the camera.
Some of the pictures taken by the Optio 30 can be found here :
Flickr: Camera Finder: Pentax: Optio 30
batteries, camera, card, digital camera, memory, optio, pentax cameras, pentax optio, point and shoot, sd, volts
Pentax announces the infinitely customizable optio rs1000 and optio rz10 with 10x zoo Adam Homepage & Official Pentax News 0 09-08-2010 09:10 PM
optio E50 problems mjd944 Pentax Compact Cameras 1 07-16-2010 12:50 PM
PENTAX UNVEILS THREE NEW DIGITAL CAMERAS: Optio I-10, Optio H90, Optio E90 Adam Homepage & Official Pentax News 11 01-26-2010 07:21 PM
Optio W60 problems LeahChi Pentax Compact Cameras 1 12-19-2009 08:04 AM
Pentax Optio Z10 problems at high ISO gubak Pentax Compact Cameras 1 04-08-2008 11:29 PM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, part of our network of photo forums!
