03-18-2010, 07:26 AM   #1
audiobomber's Avatar
Wide angle, ovf, image orientation and CHEAP
Hi. I need a camera for work. I record interior and exterior photos of buildings to post on a website. Size never exceeds 1024 pixels on the long side. The things that would make my job easier are as listed in the title: wide angle, an orientation sensor and an optical viewfinder. Easy access to Ev compensation would help as well. High ISO capability and image stabilization are not important because I use the flash or stabilize the camera for low light shooting.
Now the kicker. I can't spend more than $125.00, because that's all my company will reimburse me. I suspect I'll have to give up on the 24-35mm range, but if you know of a camera that connects all the dots, I'm all ears.
03-18-2010, 09:22 AM   #2
Pentax is a little late to the party with compact wide angles - 35-40mm equivalents used to be the norm up until a few years ago. Panasonic was probably the first brand that started going down to 28mm equiv for most of their cams.
I just did a quick search and found the olympus fe-5020 at buydig.com for $129.00. It is 24mm equivalent, but not clear whether it has an orientation sensor (dpreview says no, photography blog says only rotation - yes - could be on playback it is rotatable, which doesnt constitute an orientation sensor).
if you go to the dpreview website, in their camera database section click on feature search - you can enter the widest angle preferences (24,28,35) along with orientation sensor - yes - to give you a bunch of results. For cost, you are going to have to seek out a used/refurb or old stock discontinued camera to hit that price, but you should be able to come close!
03-18-2010, 10:25 AM   #3
QuoteOriginally posted by pxpaulx Quote
Thanks, I'll try the DPR thingie. I just got permission to go to $200 but I'll probably have to let go of one of my preferences.
03-19-2010, 05:54 AM   #4
thank good news))
you I very want rather to make an attempt DPR.
04-07-2010, 07:55 PM   #5
Pentaxie's Avatar
Yes, the Oly FE-5020 is a 24mm equivalent. I am not sure if this camera comes with an orientation sensor.
04-07-2010, 09:02 PM   #6
To finish the story, I found a FujiFilm F1500 superzoom for a really good price. I decided to keep it for my wife and use my Canon A720 IS for work. The A720 is a camera I like a lot, and taking my boring work photographs is more interesting now than it's been before.
angle, camera, digital camera, image, orientation, pentax cameras, point and shoot
Why no CHEAP wide angle lenses? bigjonnee Pentax SLR Lens Discussion 29 02-21-2010 10:12 AM
Where to get cheap wide angle and 100+ jct us101 Pentax SLR Lens Discussion 1 09-20-2009 11:14 AM
Cheap wide-angle for Program Plus BetterSense Pentax SLR Lens Discussion 14 02-01-2009 06:27 PM
Cheap Wide Angle Lenses chrislondon Pentax SLR Lens Discussion 17 02-07-2008 06:38 PM
Looking for a good cheap wide angle Finn Pentax SLR Lens Discussion 27 06-16-2007 08:03 AM
All times are GMT -7. The time now is 01:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
