Theme - "Composition"
The emphasis should be on composition. Here is what I mean
"The image should be as simplistic/minimal as possible relying mostly on the composition of the image. The use of empty spaces, rule of 3rds, sense of motion in the composition or even breaking the formal rules of composition if you can find a *bohemian* composition."
Maybe some familiar subject with a different view. The emphasis should be solely on how to present a common situation in an interesting way.
*Preferably no* or slight post-processing. Color/contrast adjustments, rotate/crop etc are fine. I think this would help bring out the real strength of composition.
It would be nice if you added a line or two describing what you had in mind when you took the picture.
THE RULES
1. Have fun!
2. No 35mm, APS, or 4/3 SLR/DSLR cameras allowed. 110 film SLRs, 35mm and smaller rangefinder/viewfindercameras are allowed. No medium or large format cameras allowed.
3. Entries will close on May 30th, 2010.
4. Maximum image dimensions are 800x800 pixels.
5. List camera brand, model with entry for all to see.
6. THEME: "Composition"
7. Max of 3 photographs per person.
8. Winner will set up and judge next contest.
Let's get rolling with our P&S's friends
