Originally posted by jake14mw Hi Nafta, so, what you are doing here is taking the SD card out of your camera, importing it into the Ipad, then watching it on the ipad? I understand why you want to do that, I have the same issue with photos. It looks good on the LCD of the camera, but when you get a really good look at it later, you realized it's not good enough. How has this been working out for you? It seems like it would be a pain to keep removing the SD card and waiting for the upload, etc.
Is there no other way to do this without removing the SD card?
There is, the iPad camera connection kit which i bought also has a usb thing. So you could connect the camera with the USB. I'm still searching on things what could make it a field monitor but this abit harder, There is a VGA adapter, so i should be able to hook the Camera to the VGA adapter. Like normally, the vga adapter will only show stuff when it's video, not the ipad self. So i need to revert the process, so that the ipad is the external source instead of the sending source. But we can surely try!
