Originally posted by enoxatnep I understand that on the K-5 when shooting video, you can only do this using Live View, which I assume means having to look at the LCD monitor. If so, does this mean that there is absolutely no way to record video while looking through the viewfinder?
Correct.
The mirror has to be lifted in order for the sensor to be exposed.
Once the mirror is up, you cannot see through the viewfinder.
If that should be a requirement,
Some companies make a eye-peice mechanism that fits over the LCD to make it easier to work with video.
Else, look into cameras that have semi-transparent mirrors that might allow viewing through the actual viewfinder while recording video.
Or some cameras that have tiny LCD screens in the viewfinder rather than true TTL.
