04-05-2011, 11:14 PM   #1
Import K-X video files into CS5?
Anyone know how to successfully do this? I can't import correctly, i just get audio. I read somewhere that it might be a problem with CS5 being 64 bit, but I can't find an explanation on how to work with that.
04-06-2011, 03:18 AM   #2
What do you mean by import and what CS5 app you are using? The movie files are on you SD card just like photos so you just drop these into your Premier? After Effects? import window. If you are on windows I can not assist you any further. If on mac try to play your video files with Quicktime. If these play correctly then it should work in CS5 as well.
What OS?
What app?
04-06-2011, 09:36 AM   #3
I'm on windows trying to drop them into premiere, I've tried most of the premiere project presets to make sure I wasn't just using the wrong project settings, but none seem to work. All I get is the audio. I tried finding a codec but I'm not sure I completely understand how to install new codecs, or if that's even the right answer to this problem.
04-07-2011, 02:33 AM   #4
I do not use Premiere, but AE can play almost any codec independent your codec installations (it has its own package I think). If you have the media CDs that came with your camera I am sure you can find something that allow you to open the movies properly there. Actually I think this will install the proper codec so you will be OK afterwards.
04-07-2011, 12:55 PM   #5
Thanks, I'll try AE first, but if anything I'll have to dig out the cd's and see if that helps. Thanks again for responding.
hdslr, import, video
How to batch rename files after files imported and tagged in Photoshop Elements raider Digital Processing, Software, and Printing 5 03-14-2013 10:36 PM
Pentax K-R DNG files and CS5 JTWilson37209 Pentax K-r 3 02-28-2011 12:55 PM
Elements 9 organiser video import help needed kangamel Digital Processing, Software, and Printing 3 12-12-2010 10:08 AM
Sync on Video files peter25 Pentax K-r 1 11-15-2010 09:02 PM
Pentax Video MJPEG Files EdwardConde Video and Pentax HDSLRs 3 10-12-2010 10:56 PM
All times are GMT -7. The time now is 09:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
